1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Segmentation fault at dbConvert.c in Ubuntu 32/64 bit
To: <[email protected]>
Date: Thu, 23 Feb 2017 09:09:55 +0100
Thanks to Freddie we have a patch now for the issue for 64 bit systems.
I have to revise that the problem also occurs at 32 bit systems. I apologize for the inconvenience.
dbConvert.c works at 32 bit system fine! The issue occurs at 64 bit systems only.
Best regards,
Carsten
Am 21.02.2017 um 11:42 schrieb [email protected]:
I think  get_precision()  expects a  long*  for the precision but the variable passed is declared   int   in getFloatString() and getDoubleString(). In theory this could cause a crash on 64 bit linux as int and long are different sizes, but It wouldn’t explain the 32bit crash though as int and long are the same size on that architecture…
Freddie
From: [email protected] [mailto:[email protected]] On Behalf Of Ralph Lange
Sent: 21 February 2017 08:54
To: Carsten Winkler
Cc: EPICS Tech Talk
Hi Carsten,
The default value for precision used when you comment out the lines you mention is 6.
Can you achieve the same (i.e. avoid segfaults) by setting PREC to 6 in your database?
If yes: which PREC values cause segfaults?
Cheers,
~Ralph
On Tue, Feb 21, 2017 at 9:15 AM, Carsten Winkler <[email protected]> wrote:
I forgot to give you the used db entry. Here it is:
record(waveform, "caLab:waveString")
    field(DESC, "String waveform record")
    field(NELM, 48)
    field(FTVL, "STRING")
    field (PINI, "YES")
    field (PREC, 3)
Am 20.02.2017 um 15:40 schrieb Carsten Winkler:
> Hi there,
> I always run into a  "Segmentation fault" in function "putFloatString" |
> "putDoubleString" of BASE/src/db/dbConvert.c
> When I comment out following lines (call of get_precision) everything is
> working again:
> 3947
> 3948
> 4157
> 4158
> Test system
> Ubunu 16.04 (64 bit)
> EPICS BASE 3.14.12.6 (64 bit)
> To check the error, I used this code:
> test.cpp
> #include <malloc.h>
> #include <cadef.h>
> //#define DOUBLE
> using namespace std;
> int main() {
>     chid chanID;
>     int iNumber = 1;
>     int timeout = 0;
>     void *pValue = 0x0;
>     ca_context_create(ca_enable_preemptive_callback);
> #if defined DOUBLE
>     pValue = (double*)malloc(iNumber*sizeof(double));
>     for(int i=0; i<iNumber; i++) {
>         ((double*)pValue)[i] = (double)((1+i)*3.1415926535897);
> #else
>     pValue = (float*)malloc(iNumber*sizeof(float));
>         ((float*)pValue)[i] = (float)((1+i)*3.1415926535897);
> #endif
>     ca_create_channel("caLab:waveString", 0, 0, 50, &chanID);
>     timeout = 3000;
>     while(ca_state(chanID) != cs_conn && timeout--) {
>         epicsThreadSleep(.001);
> #if defined DOUBLE
>     ca_array_put(DBR_DOUBLE, 1, chanID, pValue);
> #else
>     ca_array_put(DBR_FLOAT, 1, chanID, pValue);
> #endif
>     ca_context_destroy();
>     free(pValue);
>     return 0;
> g++ -I/usr/local/epics/base-3.14.12.6/include/os/Linux
> -I/usr/local/epics/base-3.14.12.6/include -O0 -g3 -Wall -c
> -fmessage-length=0 -MMD -MP -MF"test.d" -MT"test.d" -o "test.o" "test.cpp"
> g++ -L/usr/local/epics/base-3.14.12.6/lib/linux-x86_64 -o "test"
> test.o   -lCom -lca
> Any advice to solve this issue?
> Best regards
> Carsten Winkler
> PS Same problem in 32 bit systems
> ________________________________
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Dr. Karl Eugen Huthmacher, stv. Vorsitzende Dr. Jutta Koch-Unterseher
> Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
> http://www.helmholtz-berlin.de
Postadresse:
D-14109 Berlin
Postadresse:
D-14109 Berlin
--- src/db/dbConvert.c	2016-12-09 20:53:29.000000000 +0100
+++ src/db/dbConvert.c	2017-02-22 13:55:58.839396000 +0100
@@ -1628,7 +1628,7 @@
     char *pbuffer = (char *)pto;
     float	*psrc=(float *)(paddr->pfield);
     long	status = 0;
-    int		precision = 6;
+    long	precision = 6;
     struct rset	*prset = 0;
     if(paddr) prset = dbGetRset(paddr);
@@ -1838,7 +1838,7 @@
     double *psrc=(double *)(paddr->pfield);
     long	status = 0;
@@ -3940,7 +3940,7 @@
     const float *pbuffer = (const float *)pfrom;
     char	*pdest=(char *)(paddr->pfield);
     long	status = 0;
     struct rset *prset = dbGetRset(paddr);
     short size=paddr->field_size;
@@ -4150,7 +4150,7 @@
     const double *pbuffer = (const double *)pfrom;
     long	status = 0;
Segmentation fault at dbConvert.c in Ubuntu 32/64 bit Carsten Winkler
Re: Segmentation fault at dbConvert.c in Ubuntu 32/64 bit Carsten Winkler
Re: Segmentation fault at dbConvert.c in Ubuntu 32/64 bit Ralph Lange
RE: Segmentation fault at dbConvert.c in Ubuntu 32/64 bit freddie.akeroyd
Prev: RE: Re: IOC Connecting Problem Mark Rivers
Next: memory leak after unloading of ca.lib Carsten Winkler
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Segmentation fault at dbConvert.c in Ubuntu 32/64 bit Benjamin Franksen
Next: Medm Menu Object with non-sequential choices Newby, Mary A
