1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Compile error with areaDetector
To: 'Jörn Dreyer' <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 15 Nov 2017 16:18:05 +0000
Hi Jörn,
I have successfully built EPICS-CPP-4.6.0 and the master branch ntndArrayConverter.cpp with the following versions of gcc:
gcc (GCC) 4.2.1 (SUSE Linux)
gcc (GCC) 4.4.7 20120313 (Red Hat 4.4.7-18)
gcc (GCC) 4.8.5 20150623 (Red Hat 4.8.5-16)
You are getting an error with 4.8.4.  This seems strange since it builds OK for me with 2 versions of gcc that are older than yours, and one version that is slightly newer.
Are you sure you are using the released version of EPICS-CPP-4.6.0?
I believe my version of EPICS-CPP-4.6.0 is the distribution version, but with minor changes to these 2 files to fix issues with Visual Studio 2015.
exampleCPP/exampleClient/src/examplePvaClientPut.cpp
exampleCPP/exampleClient/src/examplePvaClientProcess.cpp
These changes are discussed on the Known Issues page:
http://epics-pvdata.sourceforge.net/docbuild/4.6.0/issues.html#c++_module_issues
There is no mention there of the types of errors you are getting.
-----Original Message-----
Sent: Wednesday, November 15, 2017 7:55 AM
To: [email protected]; Mark Rivers
Subject: Re: Compile error with areaDetector
Hi Mark,
I did a checkout from git with the master branch.
But the same happens if I checkout R3-1.
Jörn
Am Mittwoch, 15. November 2017, 14:05:19 CET schrieb Mark Rivers:
> Which version of ADCore?
> ________________________________
> From: Jörn Dreyer <[email protected]>
> Sent: Wednesday, November 15, 2017 6:58 AM
> To: Mark Rivers
> Cc: [email protected]
> Hi Mark,
> I'm using:
>  $gcc --version
> gcc (Ubuntu 4.8.4-2ubuntu1~14.04.3) 4.8.4
> $ lsb_release -a
> No LSB modules are available.
> Distributor ID: Ubuntu
> Description:    Ubuntu 14.04.5 LTS
> Release:        14.04
> Codename:       trusty
> Regards,
> Jörn
> > Hi Jörn,
> > I don't have experience with gcc 5.4.0.  But you say you are also getting
> > an error with gcc 4.8.  I am running gcc 4.8.5
> > and ntndArrayConverter.cpp compiles fine for me with that compiler.
> > Exactly which version of gcc 4.8 is failing for you?
> > Mark
> > From: [email protected] <[email protected]> on
> > behalf of Dreyer, Dr. Joern <[email protected]> Sent: Wednesday, November
> > 15, 2017 1:26 AM
> > Subject: Compile error with areaDetector
> > Hi,
> > I have run into a problem with areaDetector compilation when enabling
> > EPICS4 using version 4.6.0 on Ubuntu16.04.3 LTS.
> > Thanks,
problem solved. I used a different system to get acces, which did not have my
public ssh key installed in ~/.ssh. nAfter copying the key from another
system, it worked!
> > ../ntndArrayConverter.cpp: In member function ‘void
> > NTNDArrayConverter::fromUndefinedAttribute(epics::pvData::PVStructurePtr)’
> > ../ntndArrayConverter.cpp:497:54: error: no matching function for call to
> > ‘std::tr1::shared_ptr<epics::pvData::PVField>::reset() const’
> >    dest->getSubField<PVUnion>("value")->get().reset();
> > In file included from /usr/include/c++/5/tr1/memory:50:0,
> >    from
> > /home/wuestenf/EPICS/EPICS-3.15.5/EPICS-CPP-4.6.0/pvDataCPP/include/pv/sha
> > re dPtr.h:124, from
> > /home/wuestenf/EPICS/EPICS-3.15.5/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvT
> > yp e.h:41, from
> > /home/wuestenf/EPICS/EPICS-3.15.5/EPICS-CPP-4.6.0/pvDataCPP/include/pv/pvD
> > is play.h:14, from
> > /home/wuestenf/EPICS/EPICS-3.15.5/EPICS-CPP-4.6.0/normativeTypesCPP/includ
> > e/ pv/ntndarray.h:17, from ../ntndArrayConverter.h:2,
> >    from ../ntndArrayConverter.cpp:4:
> > /usr/include/c++/5/tr1/shared_ptr.h:644:7: note: candidate: void
> > std::tr1::__shared_ptr<_Tp, _Lp>::reset() [with _Tp =
> > epics::pvData::PVField; __gnu_cxx::_Lock_policy _Lp =
> > (__gnu_cxx::_Lock_policThanks,
system, it worked!
y)2u] <near match>
> >    reset() // never throws
> > /usr/include/c++/5/tr1/shared_ptr.h:644:7: note:  passing ‘const
> > PVFieldPtr* {aka const std::tr1::shared_ptr<epics::pvData::PVField>*}’ as
> > ‘this’ argument discards qualifiers
> > /usr/include/c++/5/tr1/shared_ptr.h:649:9: note: candidate: template<class
> > _Tp1> void std::tr1::__shared_ptr<_Tp, _Lp>::reset(_Tp1*) [with _Tp1 =
> > _Tp1; _Tp = epics::pvData::PVField; __gnu_cxx::_Lock_policy _Lp =
> > (__gnu_cxx::_Lock_policy)2u]
> >    reset(_Tp1* __p) // _Tp1 must be complete.
> > /usr/include/c++/5/tr1/shared_ptr.h:649:9: note:  template argument
> > deduction/substitution failed:
> > ../ntndArrayConverter.cpp:497:54: note:  candidate expects 1 argument, 0
> > provided
> >    from
> > re dPtr.h:124, from
> > yp e.h:41, from
> > is play.h:14, from
> > /usr/include/c++/5/tr1/shared_ptr.h:658:9: note: candidate: template<class
> > _Tp1, class _Deleter> void std::tr1::__shared_ptr<_Tp, _Lp>::reset(_Tp1*,
> > _Deleter) [with _Tp1 = _Tp1; _Deleter = _Deleter; _Tp =
> >    reset(_Tp1* __p, _Deleter __d)
> > /usr/include/c++/5/tr1/shared_ptr.h:658:9: note:  template argument
> > ../ntndArrayConverter.cpp:497:54: note:  candidate expects 2 arguments, 0
> > provided
> > The used gcc version is 5.4.0. On Ubuntu 14.04.5 LTS The error comes at
> > the
> > same line, but different problem:
> > ../ntndArrayConverter.cpp:497:54: error: passing ‘const PVFieldPtr {aka
> > const std::tr1::shared_ptr<epics::pvData::PVField>}’ as ‘this’ argument of
> > ‘void std::tr1::__shared_ptr<_Tp, _Lp>::reset() [with _Tp =
> > (__gnu_cxx::_Lock_policy)2u]’ discards qualifiers [-fpermissive]
> > here the used gcc version is 4.8. It look like an explicit typecast is
> > necessary here. But what would be the correct type?
> > Regards,
> > Jörn
Re: Compile error with areaDetector Jörn Dreyer
Compile error with areaDetector Dreyer, Dr. Joern
Re: Compile error with areaDetector Mark Rivers
Prev: Re: Compile error with areaDetector Jörn Dreyer
Next: RE: Problem when formating a field as HEX32 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Compile error with areaDetector Jörn Dreyer
