Hi Mark,
On 02/18/2018 08:19 AM, Mark Rivers wrote:
> We have established that the files do contain these non-UTF8
> characters. The question is, should this matter? So far the only
> problem has been observed by Kaz when building on Windows. The problem
> is in perl when creating the .d dependency files.
> My conclusion is that the characters are not a problem when using perl
> 5.14.2 or 5.16.3, but they are a problem when using perl 5.24.3. Is
> there a switch to later versions of perl that would suppress this error?
It should be possible to tell Perl to suppress its Unicode handling. Try
adding this to the build, either to some appropriate CONFIG_SITE* file,
or (my preference) to the Makefile that builds the problematic source files:
# Sources here use a non-UTF-8 encoding
PERL = perl -C0
Our default -CSD setting tells Perl that all I/O streams should be
assumed to use UTF-8 encoding; -C0 says no I/O streams use UTF-8. I
would like the EPICS default to continue to use UTF-8 if possible.
- Andrew
- RE: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Mark Rivers
- ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Gofron, Kazimierz
- RE: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Gofron, Kazimierz
- Re: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Mark Rivers
- Re: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Johnson, Andrew N.
Re: using stream -calcout Dirk Zimoch
<2018>
2025
2026
Re: ADSupport compilation problem due to GraphicsMagick Malformed UTF-8 character(s) Torsten Bögershausen
<2018>
2025
2026
