I am using linux-gpib-4.1.0 to access GPIB devices with Agilent 82357B GPIB-USB adaptor. With ibtest i can access GPIB instrument without any error. But making IOC as given in https://wiki-ext.aps.anl.gov/epics/index.php/How_to_use_GPIB_ports_with_linux-gpib_and_StreamDevice with LINUX_GPIB=YES in asyn4-33/configure/RELEASE considering https://epics.anl.gov/tech-talk/2007/msg01343.php https://epics.anl.gov/tech-talk/2008/msg00008.php The gpib library $ ls /lib/ apparmor/ klibc-k3La8MUnuzHQ0_kG8hokcGAC0PA.so systemd/ brltty/ libgpib.so.0 sysvinit/ cpp linux-sound-base/ terminfo/ crda/ lsb/ udev/ but $ /sbin/ldconfig -p |grep gpib doesn't list any gpib library. But still i am getting and error ## 2 Configure your asynPorts # 2a GPIB: portname, autoConnect, boardId, timeout, 5th_arg GpibBoardDriverConfig("agi", "1", "0", "3", "0") st.cmd line 18: Command GpibBoardDriverConfig not found. ## Load record instances dbLoadTemplate "db/user.substitutions" i am using it on ubuntu 16 with 64 bit machine. Thanks Vishnu
| ANJ, 26 Apr 2018 |
Home
News
About
Talk
Base
Modules
Extensions
