1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Modify checkbox value from a table widget
To: Pilar Gil Jaldo <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 25 Apr 2018 15:21:29 +0000
Hi:
Pete is correct in pointing out that this question lacked context.
It's about a Jython script within a CS-Studio opibuilder display that tries to set the value of a cell in a column configured to use a checkbox.
Expected behavior would be that the checkbox is set/cleared based on the value, but that didn't happen.
I've fixed the table widget code, see https://github.com/ControlSystemStudio/cs-studio/issues/2426
Once the pull request gets merged and you fetch the latest copy of CSS, you can call "table.setCellText( 1, 1, 'Yes')" and the checkbox will be set/cleared based on that value matching the labels, which default to "No" and "Yes".
Kay
Modify checkbox value from a table widget Pilar Gil Jaldo
Re: Modify checkbox value from a table widget Kasemir, Kay
Re: Modify checkbox value from a table widget Pilar Gil Jaldo
Prev: Re: Modify checkbox value from a table widget Pilar Gil Jaldo
Next: Re: Problem with autosave module making it crash at random basis. Ronald L. Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: Stringin - asynOctedRead type how to set string length Pilar Gil Jaldo
ANJ, 05 Jun 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
