1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CSS BOY enum local PV
To: "Gregory, Ray" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 26 Apr 2018 18:12:04 +0000
Hi:
If you cannot use an actual enum PV because there are too many labels,
and you can't use a local enum PV because that doesn't allow changes to the enum labels,
then don't use an enum PV.
Instead, on the combo box, un-check the option to get "Items from PV" and directly enter the items, as many as you want.
Or set the items from a script:
from org.csstudio.display.builder.runtime.script import ScriptUtil
combo = ScriptUtil.findWidgetByName(widget, "Name Of My Combo")
combo.setItems( [ "Ene", "Mene", "Muh" ] )
For more examples:
Menu CS-Studio, Utilities, Install Samples,
select the Display Builder examples,
then check out  Display Builder/controls_combo.bob
-Kay
From: [email protected] <[email protected]> on behalf of Gregory, Ray <[email protected]>
Sent: Thursday, April 26, 2018 1:58 PM
To: [email protected]
Subject: [UNTRUSTED] RE: CSS BOY enum local PV
Thank you, Kay. Can you tell me how to modify the enum labels from a script after I have defined the local enum PV as you describe?
--Ray
Sent: Thursday, April 26, 2018 1:40 PM
To: Gregory, Ray <[email protected]>; [email protected]
> Is it possible to create a local enum PV in CSS that can be used as the PV for a Combo widget that also gets its items from the PV?
Yes:
      loc://demo<VEnum>(2, "A", "B", "C", "D")
You have to provide the data type <VEnum> to get an enum.
The initializer needs to contain the initial index value, followed by the enum labels.
-Kay
CSS BOY enum local PV Gregory, Ray
Re: CSS BOY enum local PV Kasemir, Kay
RE: CSS BOY enum local PV Gregory, Ray
Prev: RE: CSS BOY enum local PV Gregory, Ray
Next: Re: NSLS-II Debian Repository in 2018 Anton Derbenev
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: rtems_cpu_usage_report Matt Rippa
ANJ, 26 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
