1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: NSLS-II Debian Repository in 2018
To: Ralph Lange <[email protected]>
Date: Thu, 26 Apr 2018 14:50:51 -0400
Hello Ralph,
thanks for the reflection! When putting the entire idea together, the aim was to: honor the existing practice (to a reasonable degree), honor the general practice, and keep the process practical (meaning git-buildpackage and all its invocation working straightforwardly). That suggests or cuts out certain ideas; say, if we decided to use <upstream>-<revision> for native packages, git-buildpackage would fail right away (e.g. epics-debhelper 8.16-1 wouldn't build).
1. Actually, in our old repository setup, there are package versions like "8.16+zjessie+nmu1". You can see the combination of "forking" and NMU concepts here, and upgrades are handled in an interesting manner. While comparison-wise squeeze < wheezy, wheezy > jessie - so "z" is added to make wheezy < zjessie. It would continue for stretch, e.g. zjessie < zstretch... As suggested in the document you mentioned, handling "forking" with the debXuY format would introduce a reusable ordering and that I picked up to replace "zjessie".
2. While the document covers native and not-native cases without "forking", it doesn't explicitly state what to do in either case -with- "forking". It is true that debXuY supersedes nmuX when taken in that context; given #1 where debXuY is a better option for simply specifying the distribution for which the package is built, putting both serve different purposes. I concur however that native and not-native cases can be distinguished by the preceding version format, 8.16+deb8u4 is native while 5.5-1+deb8u1 is not because of the hyphen. So using both additions is indeed excessive.
For NMUs in general, I have actually considered our internal build uploads to be "NMUs" regardless of the uploader being a maintainer or not. That is, Debian revision comes from epicsdeb and everything on top of that (like the upload number) is "non-maintainer". Otherwise the versioning which we expose would be different based on who uploaded the package to build based on their maintainer status.
I found an extensive discussion on a Debian mailing list, related to the topic, here. In particular, the case which I would like to cover with +nmuX is "recompilation or binary only NMU (common use case: outdated build environment, no source changes)". Digging through how "policy should document the +bN standard for binNMUs" and "allow +nmu to be used for non-native packages as well", I concluded for myself that we'd better somehow generalize to a simple case which suits needs earlier mentioned to differentiate packages.
The conclusion for now is: we are to use <upstream>+<distribution>u<upload> for native packages, and  <upstream>-<revision>+<distribution>u<upload> for non-native packages.
Anton.
Re: NSLS-II Debian Repository in 2018 Michael Davidsaver
Re: NSLS-II Debian Repository in 2018 Anton Derbenev
Re: NSLS-II Debian Repository in 2018 Ralph Lange
Prev: Re: CSS BOY enum local PV Kasemir, Kay
Next: Re: NSLS-II Debian Repository in 2018 Michael Davidsaver
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: NSLS-II Debian Repository in 2018 Ralph Lange
ANJ, 26 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
