1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: NSLS-II Debian Repository in 2018
To: "Konrad, Martin" <[email protected]>
Date: Thu, 3 May 2018 20:12:17 -0700
On 05/03/2018 11:19 AM, Konrad, Martin wrote:
> Hi Anton, Ralph,
>> I get a bit jealous every time I see "bottom-to-top" setups with
>> CIs, push triggering, automatic testing and such - that is until I
>> imagine something goes wrong and, say, a malformed input just drags a
>> trace through the entire setup.
> Sure it does. But the same is true if you build and deploy manually. We
> are trying to prevent issues by:
> - Maintaining a "master" branch which gets build into an "unstable"
> Debian repo and a "release" branch which gets build into a "release"
> Debian repo. Releasing means merging to the release branch.
> - We have set up a test network that mimics our production network. We
> deploy from the "unstable" repo into this test environment and from the
> "release" one into the production network. Nothing goes out to
> production without test and approval.
Is it still the case that moving between unstable and release involves
a rebuild in a different environment resulting in a different set
of binaries?
> - We are trying to have one piece of each device on the test network. In
> other cases we are simulating hardware. The fact that FRIB is heavily
> using VMs and only a small number of physical IOCs helps to keep the
> cost for such a test environment low.
>> Even if that doesn't break production right away, cleaning things up
>> may be troublesome.
> If we broke something we can roll back. This can be done either by
> a) reverting the bad commit in Git and waiting for the new packages to
> be build and distributed or
> b) installing an older version of the affected package(s)
> Both approaches work well for us.
>> What different in the "FRIB version numbers" is that upload comes
>> before distribution - doesn't it mean that a recent upload for, say,
>> jessie will sort as newer when compared to an older upload for
>> stretch? And the system will consider it to be newer if it sees
>> both.
> We attach the timestamp when our CI server builds the _source_ package.
> If the same source package gets build for multiple distributions the
> version number of the resulting packages is the same except for the
> distribution name. The package build for stretch ("debian09") will sort
> as newer as the one for jessie ("debian08"). This ensures we upgrade to
> the stretch package after dist-upgrading a machine.
> Regarding the Git hash in the version number: I like this feature as it
> allows me to directly correlate packages (including "unstable" builds)
> to a revision in Git. I agree that this is less important for production
> builds if they get tagged anyway. But to be honest I trust the Git hash
> more than a tag that could get modified later. We still maintain normal
> version numbers (e.g. "4.33") for readability but we never saw a reason
> to remove the additional stuff (timestamp, build number and Git hash) -
> it can easily be ignored if not needed.
> -Martin
Attachment: signature.asc
Description: OpenPGP digital signature
Re: NSLS-II Debian Repository in 2018 Anton Derbenev
Re: NSLS-II Debian Repository in 2018 Ralph Lange
Re: NSLS-II Debian Repository in 2018 Konrad, Martin
Prev: RE: EPICS Support for RedPitaya Release v2.0 Andraz Pozar
Next: Re: NSLS-II Debian Repository in 2018 Konrad, Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: NSLS-II Debian Repository in 2018 Konrad, Martin
ANJ, 03 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
