1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Store 64-bit integer in asyn parameter library?
Cc: EPICS Tech-Talk <[email protected]>
Date: Fri, 18 May 2018 17:20:21 -0500
On 05/18, Mark Rivers wrote:
> This might actually be a good case to use a double.  You get exact
> representation for 52 bits, i.e. 20 bits more than int32, or 1M times
> higher rate.
Interesting.  So that's for the IEEE 754 double-precision binary
floating-point format (64-bit).  Assuming epicsFloat64 is that, then
the maximum integer, such that it and all smaller integers can be
represented exactly, is 2^53 = 9,007,199,254,740,992 according to [1]
and [2].  And I believe the minimum is just the negation of that since
the sign has its own bit.
I had to go read about the 64-bit format [3], and apparently there's
one more bit available for the signficand, sometimes referred to as the
hidden bit, which is where the 53 comes from (i.e., 52 + 1).  The 64-bit
format stores the number in binary normalized form, so the first bit
will always be 1, so it is omitted, thus gaining one extra bit for the
significand.
Anyway, I guess I'll use asynParamFloat64, then, and return an error if
the bit rate is less than -2^53 or greater than 2^53.
Thanks!
Lewis
[1] https://stackoverflow.com/a/1848762
[2] https://stackoverflow.com/a/1848953
[3] https://en.wikipedia.org/wiki/IEEE_754-1985
Re: Store 64-bit integer in asyn parameter library? Luca Cavalli
Store 64-bit integer in asyn parameter library? J. Lewis Muir
Re: Store 64-bit integer in asyn parameter library? J. Lewis Muir
Re: Store 64-bit integer in asyn parameter library? Mark Rivers
Prev: Job Opening at Fermilab, Accelerator Instrumentation Department Dennis Nicklaus
Next: Re: Store 64-bit integer in asyn parameter library? Luca Cavalli
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Store 64-bit integer in asyn parameter library? Mark Rivers
ANJ, 19 May 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
