Hi Ignacio,
I searched for 'forced disconnect' on the epics teck-talk search [1]. There are many reports that this is a serious bug, but no concrete cause. You may try updating your other systems version to 3.14.12.7.
Without more details how your other system uses caget, it's difficult to comment further. It may be more efficient to use a camonitor implementation in your other systems application.
-Matt
Hello everyone, Thanks for the responses. Just to add more info, we have another system (with IP 172.17.102.130) that's reading tcs:ak:astCtx with a caget. Whenever we see the "not found" message on our test, we see this message on the TCS ioc console,
Jul 12 12:40:59 E) PORT: tcs_vme, MSG: CAS: Request from 172.17.102.130:57113 => cmmd=12 cid=0xffffffff type=0 count=0 postsize=0 Jul 12 12:40:59 E) PORT: tcs_vme, MSG: CAS: Request from 172.17.102.130:57113 => available=0x1 N=0 paddr=0x0
The other system uses EPICS3.14.8.2
Thanks again, Saludos, Ignacio A.
On 07/12/2018 01:12 PM, Andrew Johnson wrote:
> Hi Matt,
> On 07/12/2018 02:54 PM, Matt Rippa wrote:
>> We ran a simple caget (once per second) from a linux host to an upgraded
>> IOC. With the new rtems/3.14.12.7 <http://3.14.12.7> IOC, it often
>> experiences timeouts as shown below. With our legacy vxworks/3.13.9 IOC
>> there are no timeouts logged. Relevant info is shown below. The
>> caRepeater is running on the linux host.
> If your IOC is busy the caget default search timeout of 1 second may be
> too short, have you tried using 'caget -w 5 tcs:ak:astCtx' say?
@Matt, If this doesn't have an effect I'd suggest taking a packet capture
to see whether these is a search reply coming back.
As it happens, I had an symptom similar to this while playing around
with an mvme31000 emulator. The issue turned out to be dropped RX
interrupts due to a bug in the emulator. The effect was due to
a hard coded 1 second timeout in CA during TCP connect().
Have you tried the simple test of letting 'ping' run for a while?
If the reported latencies aren't stable, it may be a sign of a
lower level issue.
>> I'm thinking that setting the linux host EPICS_CA_ADDR_LIST=YES may
>> help. I'm running that test now.
> I have never seen an EPICS_CA_ADDR_LIST as long as yours, but given that
> you seem to be searching multiple subnets maybe you do need that.
Agreed. For this test I'd suggest setting EPICS_CA_ADDR_LIST with only
the IP of the IOC you're testing. Along with EPICS_CA_AUTO_ADDR_LIST=NO
> I don't think setting EPICS_CA_AUTO_ADDR_LIST to YES will make any
> difference to this behaviour (your epicsPrtEnvParams showed it as YES
> already, so unless you have explicitly changed it for the client you're
> probably already searching your local subnet as well).
Also if both IOC and client tools are 3.14.12.x then you can try
EPICS_CA_AUTO_ADDR_LIST=NO EPICS_CA_ADDR_LIST= EPICS_CA_NAME_SERVERS=<IP>
This will skip the UDP search altogether and do a TCP search.
> HTH,
> - Andrew
>> EPICS_CA_ADDR_LIST=172.17.2.255 172.17.3.255 172.17.102.130
>> 172.17.105.20 172.16.102.130 aom-vme sbfmcao01.cl.gemini.edu
>> mcao-stealth.cl.gemini.edu 172.17.106.111 172.17.105.37
>> 172.17.107.50 172.17.55.101 172.17.101.101 172.17.65.255
>> 172.17.102.139 172.17.102.138
>> linux> caget tcs:ak:astCtx
>> tcs:ak:astCtx 0
>> Channel connect timed out: 'tcs:ak:astCtx' not found.
>> tcs:ak:astCtx 0
- caget randomly returns Channel connect timed out Matt Rippa
- Re: caget randomly returns Channel connect timed out Andrew Johnson
- Re: caget randomly returns Channel connect timed out Michael Davidsaver
- Re: caget randomly returns Channel connect timed out Ignacio
Mettler Toledo New Classic ML Pearson, Matthew R.
<2018>
2025
2026
<2018>
2025
2026
ANJ, 13 Jul 2018 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
