1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Some questions from a first-time driver author
To: Mark Rivers <[email protected]>, [email protected]
Date: Tue, 31 Jul 2018 09:26:08 +1000
On Mon, 30 Jul 2018, at 10:07 PM, Mark Rivers wrote:
> Is this device the Southern Innovation SITORO?
Yes, it's our FalconX device - which is sold through XIA as you note.
> If so, I have written an  asyn driver for the version of the SITORO called the FalconX from XIA,
> using their Handel library.  I assume you want to use your native library
The driver I'm working on should more be a complement to your excellent rather than an equivalent - it's specialized around high throughput multi detector list mode capture and storage. The two drivers should work quite nicely alongside each other.
One of the requirements of this driver is that it be able to work standalone - without XIA's Handel - so it does use our native library directly as you surmised.
> but even so you might want to look at that driver to see how to
> use asyn to take care of much of the code for interfacing to records,
> etc.  It polls in a separate fast thread so it can detect acquisition
> completion quickly.
Thanks. I'll take a look.
  Zik Saleeba, Senior Software Engineer
  [email protected]
Some questions from a first-time driver author Zik Saleeba
Re: Some questions from a first-time driver author Mark Rivers
Prev: Re: Some questions from a first-time driver author Zik Saleeba
Next: Compiler error on Debian Stretch arm Florian Feldbauer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Some questions from a first-time driver author Mark Rivers
Next: Aerotech Ensemble coordinated motion Douglas Henrique C . de Araújo
ANJ, 31 Jul 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
