1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: dbGetPdbAddrFromLink dropped from 3.15 again
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS Techtalk <[email protected]>
Date: Wed, 8 Aug 2018 10:12:00 -0700
Hi Andrew.
Thanks for dealing with this issue.
I thought there were two problems to deal with:
  1. internals/representation/semantics of DBADDR may change in the future
  2. 'life-time' of the information in DBADDR
Regarding 2. I agree that a callback would be the best solution. However, if you pass a DBADDR* to that callback then its internals are obviously still exposed and part of the API. That's why I suggested passing a buffer pointer/#-elements/type instead.
I would be fine with DBADDR*, too, of course.
Since 1. is (I hope) not going to happen in the 3.15 series there is no need for a new API in 3.15 since I can simply 'redefine' the macro for my legacy application(s) assuming that
 - DBADDR won't change in 3.15 and is the same as in 3.14
 - its contents do not change 'asynchronously' which I wouldn't assume to happen under 3.15    in a legacy application (links don't change, no funny double-buffering of arrays).    My application -- after obtaining the DBADDR* -- just de-references it and computes stuff
   from the buffer contents but doesn't call back into EPICS.
In a nutshell: for 3.15 my work-around is re-defining the legacy macro and for future releases
I hope for a suitable API to appear :-)
Best regards
- Till
On 08/08/2018 09:26 AM, Johnson, Andrew N. wrote:
Hi Till,
I’m okay with stretching this conversation out, you’re the one who’s asking for a solution...
The dbAddr is designed to hold all the information you want and I don’t mind giving out a pointer to one as long as its lifetime is clear. A callback makes that obvious, whereas the original dbGetPdbAddrFromLink() obscures it.
Your suggestion to add a routine dbGetLinkBufPtr() suffers from the exact same problem, because while the other two dbGet... routines return information that is current at the time of the call, for another link type such as dbCa that could change immediately after they return. In 3.16 or 7.0 we already added another API with a callback which requires the link type to hold its internal mutex for the duration of the callback, so it can fetch data and metadata from the link atomically (e.g. value and timestamp).
Are you looking for this new API to appear in the 3.15 series? We can’t add a new LSET method here because we already added the other one in the later series, but I’d be okay with doing this as a special case for the earlier versions and adding the new LSET method in the later series to preserve backwards compatibility in out link types.
- Andrew
dbGetPdbAddrFromLink dropped from 3.15 again Till Straumann
Re: dbGetPdbAddrFromLink dropped from 3.15 again Michael Davidsaver
Re: dbGetPdbAddrFromLink dropped from 3.15 again Johnson, Andrew N.
Re: dbGetPdbAddrFromLink dropped from 3.15 again Andrew Johnson
Re: dbGetPdbAddrFromLink dropped from 3.15 again Till Straumann
Prev: Re: Inverting control inputs on SIS3280? Mark Rivers
Next: Re: Inverting control inputs on SIS3280? Jesse Hopkins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: dbGetPdbAddrFromLink dropped from 3.15 again Johnson, Andrew N.
Next: Personal EPICS Building Environment Jeong Han Lee
ANJ, 08 Aug 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
