1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: streamdevice I/O Intr
From: William Kirstaedter via Tech-talk <[email protected]>
To: Dirk Zimoch <[email protected]>, [email protected]
Date: Thu, 29 Nov 2018 17:41:31 +0100
The device is connected to Ethernet.
The guy who made it wrote a java program to read and control it, so I dont really think timing is an issue but I will of course try that too.
William Kirstaedter (PP&B)
Fritz-Haber-Institut der MPG
Faradayweg 4-6
14195 Berlin
Tel: 030 8413 5405
Mail: [email protected]
Am 29.11.2018 um 17:36 schrieb Dirk Zimoch via Tech-talk:
The PRIO "HIGH" setting should give the output priority over the input in the StreamDevice layer. But when you see the output string in asyn trace, it is already through the StreamDevice layer. So everything seems fine from the StreamDevice point of view. Also asyn prints this as it writes its output. Thus from the asyn point of view everything is fine as well.
What type of connection do you have to the device? RS232?
I have seen RS232 devices, that needed some time between characters. (Maybe they don't have an input buffer?) When you type in the command manually, there is usually plenty of time between the chars, but from a program, there isn't.
What if you write to the serial port from the command line, like:
echo -en "STM\r" > /dev/ttyS0
If that also does not work, then it may be a the character timing.
I have once written an asynInterposeDelay driver to spit out chars one by one (code attached).
Usage like this:
drvAsynSerialPortConfigure "device", "/dev/ttyS0"
asynInterposeDelay "device", 0, 0.001
It supports dynamic change of the delay as well, so you don't need to reboot to find the best delay:
asynShowOption "device", 0, "delay"
asynSetOption "device", 0, "delay", 0.05
Maybe that helps.
Dirk
On 29.11.2018 17:00, William Kirstaedter via Tech-talk wrote:
Yes, I am issuing
caput CRYVISIL:TC09:Toggle 0
when the IOC starts and the device doesnt already send data, I am able to toggle with
caput CRYVISIL:TC09:Toggle 1
which results in "STM\r" showing up in the asyn TraceMask, followed by the stream.
When simulating the process "by hand" with telnet, it's no problem sending STM and ETM.
Faradayweg 4-6
14195 Berlin
Tel: 030 8413 5405
Mail:[email protected]
Am 29.11.2018 um 16:10 schrieb Michael Westfall via Tech-talk:
How are you commanding the bo record?
Are you sure its value is being commanded to zero when you want to stop reading?
Did you try something like, 'caput xxx:Toggle 0' ?
On Thu, Nov 29, 2018 at 10:21 AM William Kirstaedter via Tech-talk <[email protected] <mailto:[email protected]>> wrote:
    Hi Dirk,
    thanks for the quick answer.
    I have set
    field(PRIO, "HIGH")
    but this doesnt seem to do anything?
    I have asynTraceMask on aswell but I dont see the "ETM" command ever
    pass through...
    Faradayweg 4-6
    14195 Berlin
    Tel: 030 8413 5405
    Am 29.11.2018 um 13:37 schrieb Dirk Zimoch via Tech-talk:
    > Hi William,
    > Have you tried to give the output record a high priority?
    > Dirk
    > On 29.11.2018 13:27, William Kirstaedter via Tech-talk wrote:
    >> I'm sorry to send this again but my first mail got soft-rejected
    >> because I wasnt a subscriber.
    >> William Kirstaedter (PP&B)
    >> Fritz-Haber-Institut der MPG
    >> Faradayweg 4-6
    >> 14195 Berlin
    >> Tel: 030 8413 5405
    >> Mail: [email protected]
    >> Am 29.11.2018 um 11:34 schrieb William Kirstaedter:
    >>> Hi,
    >>> I have a small problem with a fast Device, maybe somebody already
    >>> had this problem and can help out? :)
    >>> It runs via I/O Intr.
    >>> I am able to start the reporting, but I cant stop it. It seems
    that
    >>> the stop command doesnt get through....
    >>> could it be that somehow the communication is blocked by the fast
    >>> input? how could I fix that?
    >>> Its really simple to control:
    >>> You send "STM\r", it starts reporting every 18ms
    >>> "tmp,<float>,<float>\r"
    >>> You send "ETM\r", it stops doing that, terminating communication
    >>> with "txx\r".
    >>> all ASCII formatted.
    >>> my records:
    >>> tc.db file:
    >>> record(bo, "$(P):$(R):Toggle"){
    >>>    field(DESC, "Toggle Reading")
    >>>    field(DTYP, "stream")
    >>>    field(OUT, "@tc.proto toggle $(BUS)")
    >>>    field(ZNAM, "ETM")
    >>>    field(ONAM, "STM")
    >>>    field(VAL, "0")
    >>> record(ai, "$(P):$(R):Temperature") {
    >>>   field(DESC, "Temperature")
    >>>   field (DTYP, "stream")
    >>>   field (INP, "@tc.proto read_K $(BUS)")
    >>>   field (SCAN, "I/O Intr")
    >>>   field(EGU, "K")
    >>> record(ai, "$(P):$(R):ThermoVoltage"){
    >>>   field(DESC, "TC Thermovoltage")
    >>>   field(INP, "@tc.proto read_nV $(BUS)")
    >>>   field(SCAN, "I/O Intr")
    >>>   field(EGU, "nV")
    >>> tc.proto file:
    >>> Terminator = CR;
    >>> ExtraInput = Ignore;
    >>> toggle {
    >>>         out "%{ETM|STM}";
    >>>         in "txx";
    >>> read_K {
    >>>         in "tmp,%f,%*f";
    >>> read_nV {
    >>>         in "tmp,%*f,%f";
    >> Das FHI verarbeitet, speichert und loescht Daten im Rahmen seiner
    >> Geschaeftstaetigkeit gemaess der Datenschutz-Grundverordnung
    (DSGVO)
    >> [General Data Protection Regulation (GDPR)] der Europaeischen
    Union.
    Geschaeftstaetigkeit gemaess der Datenschutz-Grundverordnung (DSGVO)     [General Data Protection Regulation (GDPR)] der Europaeischen Union.
Mike Westfall
Control Systems Software Engineer
---------------------------------------------------------------------- Das FHI verarbeitet, speichert und loescht Daten im Rahmen seiner Geschaeftstaetigkeit gemaess der Datenschutz-Grundverordnung (DSGVO) [General Data Protection Regulation (GDPR)] der Europaeischen Union.
Re: streamdevice I/O Intr William Kirstaedter via Tech-talk
Re: streamdevice I/O Intr Dirk Zimoch via Tech-talk
Re: streamdevice I/O Intr Michael Westfall via Tech-talk
Prev: Re: Question about this mailing list J. Lewis Muir via Tech-talk
Next: Re: streamdevice I/O Intr Dirk Zimoch via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: streamdevice I/O Intr Dirk Zimoch via Tech-talk
Next: Fwd: Re: streamdevice I/O Intr William Kirstaedter via Tech-talk
ANJ, 30 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
