1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: FW: Build failure when compiling synApps from source
From: Jeong Han Lee via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 12 Dec 2018 15:43:09 +0100
Hi Iain,
  I have one more question :
Could you install epics through cross-compiler or on the linux-arm directly?
  If you do on the linux-arm directly, could you install epics through
  https://github.com/jeonghanlee/epics_manifest  ?
You can simply follow README to how it works. I don't recommend to use this, but I would like to see whether your OS has issues or not.
  It doesn't contain the synApps, but some of them with proper orders.
Maybe this is not the proper way, meanwhile I am setup with synApp on my old RPi.
  Best,
  Han
On 12/12/18 3:37 PM, Jeong Han Lee wrote:
Hi Iain,
   Which EPICS BASE do you use?
   Han
On 12/12/18 3:09 PM, Iain Marcuson via Tech-talk wrote:
asyn/config/RELEASE does point to $(SUPPORT)/seq-2-2-5.
*Sent:* Tuesday, December 11, 2018 3:24 PM
*To:* Iain Marcuson <[email protected]>; Johnson, Andrew N. <[email protected]>
*Subject:* RE: FW: Build failure when compiling synApps from source
Does asyn/config/RELEASE have an entry that correctly points to $(SUPPORT)/seq-2-2-5?  If so, it should find the rule to build .st files.
*From:* [email protected] <mailto:[email protected]> <[email protected] <mailto:[email protected]>> *On Behalf Of *Iain Marcuson via Tech-talk
*Sent:* Tuesday, December 11, 2018 2:04 PM
*To:* Johnson, Andrew N. <[email protected] <mailto:[email protected]>>
*Cc:* [email protected] <mailto:[email protected]>
The synApps RELEASE files point to $(SUPPORT)/seq-2-2-5.  That said, how would I install EPICS and synApps in a distinct directory if I need to include the source?
Iain.
*From:* Johnson, Andrew N. <[email protected] <mailto:[email protected]>>
*Sent:* Tuesday, December 11, 2018 2:57 PM
*To:* Iain Marcuson <[email protected] <mailto:[email protected]>>; [email protected] <mailto:[email protected]>
*Subject:* Re: FW: Build failure when compiling synApps from source
Hi Iain,
On 12/11/18 1:20 PM, Iain Marcuson via Tech-talk wrote:
    I was able to build the standalone sequencer fine.  Yokogawa appears to build, but asyn fails with
    make[4]: *** No rule to make target `ipSNCServer.o', needed by `libtestIPServerSupport.a'.  Stop.
The sequencer provides its own set of build rules which the EPICS build system will pull in automatically from the sncseq module when you list it in your application's configure/RELEASE file. This isn't happening for you, and I suspect you're trying to use a modified build system since you also wrote this earlier:
    -snc binary in /opt/epics/bin/linux-arm
That isn't how the sequencer normally comes, GNUmake needs to see the contents of the sncseq/configure/RULES_BUILD file for any application that needs to compiler sequence programs.
- Andrew
Re: FW: Build failure when compiling synApps from source Jeong Han Lee via Tech-talk
Build failure when compiling synApps from source Iain Marcuson via Tech-talk
Fw: Build failure when compiling synApps from source Mark Rivers via Tech-talk
FW: Build failure when compiling synApps from source Iain Marcuson via Tech-talk
Re: FW: Build failure when compiling synApps from source Johnson, Andrew N. via Tech-talk
RE: FW: Build failure when compiling synApps from source Iain Marcuson via Tech-talk
Prev: Re: FW: Build failure when compiling synApps from source Jeong Han Lee via Tech-talk
Next: record field max length? William Kirstaedter via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: Re: FW: Build failure when compiling synApps from source Jeong Han Lee via Tech-talk
ANJ, 13 Dec 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
