Subject: |
Re: FW: Build failure when compiling synApps from source |
Jeong Han Lee via Tech-talk <[email protected]> |
To: |
[email protected] |
Date: |
Thu, 13 Dec 2018 14:30:58 +0100 |
Hi Iain,
INSTALL_LOCATION in BASE and SYNAPPS should be different. "make
clean or uninstall" will remove the BASE also. So it is better to use
other directory.
I tested two tests on Debian 9 and Raspbian 9 as following
environment variables:
* Debian 9
EPICS_BASE=/opt/epics
SUPPORT=/home/jhlee/playground/synApps/support
* Raspbian 9
SUPPORT=/home/pi/playground/synApps/support
With the enclosed instruction, I can install all on Debian 9
(linux_x86_64) and all except DXP and DXPSITORO on Raspbian 9
(linux-arm) without any issues. You may try to do this first, and switch
the INSTALL_LOCATION of synApps differently, for example,
/opt/epics/synApps-6.0.0 .
I may try it later, since my old Raspberry Pi is not so powerful, it
takes a lot of time to do this.
All what I've done is that I configured and installed with the
direct compiling on each architecture.
HTH,
Han
On 12/12/18 3:43 PM, Jeong Han Lee wrote:
Hi Iain,
I have one more question :
Could you install epics through cross-compiler or on the linux-arm
directly?
If you do on the linux-arm directly, could you install epics through
https://github.com/jeonghanlee/epics_manifest ; ?
You can simply follow README to how it works. I don't recommend to
use this, but I would like to see whether your OS has issues or not.
It doesn't contain the synApps, but some of them with proper orders.
Maybe this is not the proper way, meanwhile I am setup with synApp on
my old RPi.
Best,
Han
On 12/12/18 3:37 PM, Jeong Han Lee wrote:
Hi Iain,
Which EPICS BASE do you use?
Han
On 12/12/18 3:09 PM, Iain Marcuson via Tech-talk wrote:
asyn/config/RELEASE does point to $(SUPPORT)/seq-2-2-5.
*Sent:* Tuesday, December 11, 2018 3:24 PM
*To:* Iain Marcuson <[email protected]>; Johnson,
Andrew N. <[email protected]>
*Subject:* RE: FW: Build failure when compiling synApps from source
Does asyn/config/RELEASE have an entry that correctly points to
$(SUPPORT)/seq-2-2-5? If so, it should find the rule to build .st
files.
<mailto:[email protected]> <[email protected]
<mailto:[email protected]>> *On Behalf Of *Iain Marcuson
via Tech-talk
*Sent:* Tuesday, December 11, 2018 2:04 PM
*To:* Johnson, Andrew N. <[email protected] <mailto:[email protected]>>
*Cc:* [email protected] <mailto:[email protected]>
The synApps RELEASE files point to $(SUPPORT)/seq-2-2-5. That said,
how would I install EPICS and synApps in a distinct directory if I
need to include the source?
Iain.
*From:* Johnson, Andrew N. <[email protected] <mailto:[email protected]>>
*Sent:* Tuesday, December 11, 2018 2:57 PM
<mailto:[email protected]>>; [email protected]
*Subject:* Re: FW: Build failure when compiling synApps from source
Hi Iain,
On 12/11/18 1:20 PM, Iain Marcuson via Tech-talk wrote:
I was able to build the standalone sequencer fine. Yokogawa
appears to build, but asyn fails with
make[4]: *** No rule to make target `ipSNCServer.o', needed by
`libtestIPServerSupport.a'. Stop.
The sequencer provides its own set of build rules which the EPICS
build system will pull in automatically from the sncseq module when
you list it in your application's configure/RELEASE file. This isn't
happening for you, and I suspect you're trying to use a modified
build system since you also wrote this earlier:
-snc binary in /opt/epics/bin/linux-arm
That isn't how the sequencer normally comes, GNUmake needs to see the
contents of the sncseq/configure/RULES_BUILD file for any application
that needs to compiler sequence programs.
- Andrew
git clone https://git.launchpad.net/epics-base
cd epics-base
git checkout 0649a2f1
git submodule update --init --reference ./
echo "INSTALL_LOCATION=/opt/epics" > configure/CONFIG_SITE.local
sudo make
wget -c https://epics.anl.gov/bcda/synApps/tar/synApps_6_0.tar.gz
tar xvzf synApps_6_0.tar.gz
cd synApps/support/
echo "SUPPORT=/home/pi/playground/synApps/support" > configure/SUPPORT.linux-arm
echo "EPICS_BASE=/opt/epics" > configure/EPICS_BASE.linux-arm
export EPICS_HOST_ARCH=linux-arm
echo "SUPPORT=/home/jhlee/playground/synApps/support" > configure/SUPPORT.linux-x86_64
echo "EPICS_BASE=/opt/epics" > configure/EPICS_BASE.linux-x86_64
export EPICS_HOST_ARCH=linux-x86_64
Disable DXP
Disable DXPSITORO
configure/RELEASE
#DXP=$(SUPPORT)/dxp-R5-0
#DXPSITORO=$(SUPPORT)/dxpSITORO-R1-1
make release
make clean uninstall
make
# apt install libnet1-dev libpcap-dev
- RE: FW: Build failure when compiling synApps from source Iain Marcuson via Tech-talk
- Build failure when compiling synApps from source Iain Marcuson via Tech-talk
- Fw: Build failure when compiling synApps from source Mark Rivers via Tech-talk
- FW: Build failure when compiling synApps from source Iain Marcuson via Tech-talk
- Re: FW: Build failure when compiling synApps from source Johnson, Andrew N. via Tech-talk
- Re: FW: Build failure when compiling synApps from source Jeong Han Lee via Tech-talk
Re: record field max length? William Kirstaedter via Tech-talk
Re: record field max length? Dirk Zimoch via Tech-talk
<2018>
2025
2026
<2018>
2025
2026
