1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Pro-Dex Oregon Micro Systems EPICS hardware support
To: "Peterson, Kevin M." <[email protected]>
Date: Fri, 22 Feb 2019 00:04:35 +0000
Hi Kevin,
Thanks for getting back to me. I will keep a look out for changes related to the motor repository splitting.
In order to test the drivers for the MAXv, I am planning to use a VME rack with Emerson MVME 5500 card. I believe the card was tested in the past by booting RTEM with EPICS from a server using FTP. For testing a MAXv or MAXnet, what are your suggestions for an operating system and boot method? I have found on the EPICS website how to boot a soft IOC Linux box. It appears that Linux is now more of the movement to run EPICS on than RTEMS.
Earl
Earl Green | Software Engineer
800.707.8111 (Main)
503.629.8081 (Office)
503.629.0688 (Fax)
Visit our website: www.OMSmotion.com
Sent: Wednesday, February 20, 2019 2:56 PM
To: Rivers, Mark L.; Earl Green
Cc: [email protected]
Earl,
Everything Mark said is correct.  I hope to begin the split of the motor
repository very soon.
I subscribe to tech-talk, but the number of unread tech-talk messages in
my inbox is usually much higher than I care to admit.
Kevin
On 2/19/19 6:32 PM, Mark Rivers via Tech-talk wrote:
> Hi Earl,
> The EPICS motor software is in this repository on Github:
> https://github.com/epics-modules/motor
> The software for your company’s products is in these 2 directories:
> https://github.com/epics-modules/motor/tree/master/motorApp/OmsSrc
> https://github.com/epics-modules/motor/tree/master/motorApp/OmsAsynSrc
> There is a plan to split up the motor repository into a base module with
> the core code, and then separate repositories for each vendor.  I think
> this is planned for the near future.
> The best person to talk to is Kevin Peterson at the Advanced Photon
> Source at Argonne ([email protected] <mailto:[email protected]>).
> Mark
Re: Pro-Dex Oregon Micro Systems EPICS hardware support Heinz Junkes via Tech-talk
Pro-Dex Oregon Micro Systems EPICS hardware support Earl Green via Tech-talk
RE: Pro-Dex Oregon Micro Systems EPICS hardware support Mark Rivers via Tech-talk
Re: Pro-Dex Oregon Micro Systems EPICS hardware support Peterson, Kevin M. via Tech-talk
Prev: RE: EPICS and VXI query Moore, Tom via Tech-talk
Next: GNU Screen or procServ on ARM? John Dobbins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: Pro-Dex Oregon Micro Systems EPICS hardware support Peterson, Kevin M. via Tech-talk
Next: Re: Pro-Dex Oregon Micro Systems EPICS hardware support Heinz Junkes via Tech-talk
ANJ, 22 Feb 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
