Unfortunately, I had to give up here due to lack of time. I couldn't communicate
with this Keithley IP-asyn-driver.
I am now on Streamdevice
(Danke Christoph)
not sure what driver you are trying to use, but you can also use the
Streamdevice support from LBNL:
https://epics.anl.gov/download/modules/index.php
https://epics.anl.gov/download/modules/Keithley6487-1.1.tar.gz
the Keithley 6485 is basically a Keithley 6487 with fewer functionality
(no limit Tests and Voltage source). Most commands are supported by the
6485 as well.
It's used like any other Streamdevice support.
Best regards,
Christoph
Gruss,
Heinz
> On 6. Mar 2019, at 14:51, Heinz Junkes via Tech-talk <[email protected]> wrote:
> Looks much better.
> Now I get it. The function drvAsynKeithley648x returns a port for communicating. I hadn't understood that.
> drvAsynIPPortConfigure("MOXA_4", "172.24.192.29:4004", 0, 0, 0)
> drvAsynKeithley648x("6485", "Keithley6485", "MOXA_4",0)
> 2019/03/06 14:47:24.055 Keithley6485 writeRead: error 1 wrote "*IDN?"
> drvAsynKeithley648x::drvAsynKeithley6485 port Keithley6485 failed to acquire identification
> asynSetTraceIOMask("MOXA_4", 0, 0x2)
> asynSetTraceMask("MOXA_4", 0, 0x9)
> dbLoadRecords("db/Keithley6485.db", "P=trARPES:, CA=Sample:, PORT=Keithley6485”)
> 2019/03/06 14:48:46.391 trARPES:Sample:read devAsynFloat64::processCallbackInput process read error
> 2019/03/06 14:48:46.391 trARPES:Sample:readStatusOverflow devAsynInt32::processCallbackInput process read error
> 2019/03/06 14:48:46.391 trARPES:Sample:readStatusFilter devAsynInt32::processCallbackInput process read error
> 2019/03/06 14:48:46.392 trARPES:Sample:readStatusMath devAsynInt32::processCallbackInput process read error
> 2019/03/06 14:48:46.392 trARPES:Sample:readStatusNull devAsynInt32::processCallbackInput process read error
> 2019/03/06 14:48:46.392 trARPES:Sample:readStatusLimits devAsynInt32::processCallbackInput process read error
> 2019/03/06 14:48:46.392 trARPES:Sample:readStatusOvervoltage devAsynInt32::processCallbackInput process read error
> Now I have to check if the device is connected ;-)
> Danke,
> Heinz
>> On 6. Mar 2019, at 14:28, Mark Rivers <[email protected]> wrote:
>> OK, so the actual code to create the port is this, it does take 4 arguments:
>> int drvAsynKeithley648x(const char *type, const char *myport,
>> const char *ioport, int ioaddr)
>> So your code should call
>> dbLoadRecords("db/Keithley6485.db", "P=trARPES:, CA=Sample:, PORT=Kiethley6485")
>> What do you see if you try that?
>> ________________________________
>> From: Heinz Junkes <[email protected]>
>> Sent: Wednesday, March 6, 2019 7:09 AM
>> To: Mark Rivers
>> Cc: [email protected]
>> Subject: Re: epics-Keithley_648x, drvAsynKeithley648x
>> Hello, Mark,
>> thank you for your answers. Unfortunately it doesn't work that way either:
>> startup
>> drvAsynKeithley648x("6485", "MOXA_4",0)
>> drvAsynKeithley648x::drvAsynKeithley6485 port MOXA_4 can't connect to asynCommon on Octet server 0 address 0.
>> dbLoadRecords("db/Keithley6485.db", "P=trARPES:, CA=Sample:, PORT=6485")
>> The driver is from https://github.com/dohnarms/epics-Keithley_648x
>> In the driver there seems to be a mismatch
>> /* Public interface forward references */
>> int drvAsynKeithley648x(const char* myport,const char* ioport, int ioaddr);
>> * Define public interface methods
>> int status = asynSuccess;
>> Port* pport;
>> // int i;
>> asynStandardInterfaces *pInterfaces;
>> char inpBuf[BUFFER_SIZE];
>> int eomReason;
>> pport = (Port*)callocMustSucceed(1,sizeof(Port),"drvAsynKeithley6485");
>> * Register public methods
>> /* Initialization method definitions */
>> static const iocshArg arg0 = {"type",iocshArgString};
>> static const iocshArg arg1 = {"myport",iocshArgString};
>> static const iocshArg arg2 = {"ioport",iocshArgString};
>> static const iocshArg arg3 = {"ioaddr",iocshArgInt};
>> static const iocshArg* args[]= {&arg0,&arg1,&arg2,&arg3};
>> static const iocshFuncDef drvAsynKeithley648xFuncDef =
>> {"drvAsynKeithley648x",4,args};
>> static void drvAsynKeithley648xCallFunc(const iocshArgBuf* args)
>> drvAsynKeithley648x(args[0].sval,args[1].sval,args[2].sval,args[3].ival);
>> /* Registration method */
>> static void drvAsynKeithley648xRegister(void)
>> static int firstTime = 1;
>> if( firstTime )
>> firstTime = 0;
>> iocshRegister( &drvAsynKeithley648xFuncDef,drvAsynKeithley648xCallFunc );
>> epicsExportRegistrar( drvAsynKeithley648xRegister );
>> That is why I have given four arguments in the st.cmd.
>> Danke,
>> Heinz
>>> On 6. Mar 2019, at 13:51, Mark Rivers <[email protected]> wrote:
>>> My comments are:
>>> Your original message says that drvAsynKeithley6845 take 3 arguments. Your actual commands call drvAsynKeithey648x with 4 arguments. Why the difference? Does 648x take an initial argument with the exact model number, or is that the name of the new port?
>>> I don't see the need for the asynOctetConnect line.
>>> Maybe this will work:
>>> dbLoadRecords("db/Keithley6485.db", "P=trARPES:, CA=Sample:, "6845")
>>> I deleted the asynOctetConnect, deleted the 3 argument to drvKeithley648x, and changed the port passed in dbLoadRecords.
>>> Is this driver code on Github or somewhere else we can look at it?
>>> Mark
smime.p7s
Description: S/MIME cryptographic signature
- Re: epics-Keithley_648x, drvAsynKeithley648x Arms, Dohn A. via Tech-talk
- RE: epics-Keithley_648x, drvAsynKeithley648x Mark Rivers via Tech-talk
- epics-Keithley_648x, drvAsynKeithley648x Heinz Junkes via Tech-talk
- Re: epics-Keithley_648x, drvAsynKeithley648x Mark Rivers via Tech-talk
- Re: epics-Keithley_648x, drvAsynKeithley648x Heinz Junkes via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
