1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: RE: drvAsynIPPortConfigure and I/O Intr with asynRecord possible?
To: 'Benjamin Franksen' <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Mon, 8 Apr 2019 16:56:00 +0000
Hi Ben,
I figured it out.  drvAsynIPPort does the following during initialization:
    pasynOctet->read = readIt;
    pasynOctet->write = writeIt;
    pasynOctet->flush = flushIt;
    tty->octet.interfaceType = asynOctetType;
    tty->octet.pinterface  = pasynOctet;
    tty->octet.drvPvt = tty;
    status = pasynOctetBase->initialize(tty->portName,&tty->octet, 0, 0, 1);
    if(status != asynSuccess) {
        printf("drvAsynIPPortConfigure: pasynOctetBase->initialize failed.\n");
        ttyCleanup(tty);
        return -1;
Note that it calls pasynOctetBase->initialize() with a final argument of 1.
This is the initialize code that it calls in interfaces/asynOctetBase.c
static asynStatus initialize(const char *portName,
    asynInterface *pdriver,
    int processEosIn,int processEosOut,
    int interruptProcess)
    octetPvt   *poctetPvt;
    poctetPvt->interruptProcess = interruptProcess;
    if(interruptProcess) {
        status = pasynManager->registerInterruptSource(
            portName,&poctetPvt->octetBase,&poctetPvt->pasynPvt);
        if(status!=asynSuccess) {
            printf("registerInterruptSource failed\n");
            return status;
The final argument to the initialize() function is thus interruptProcess, and if that is non-zero then the initialize routine calls pasynManager->registerInterruptUser() for the asynOctet interface.
So the drvAsynIPPort driver does explicitly ask for pasynManager->registerInterruptUser() to be called on the asynOctet interface.
Marty wrote this code a long time ago, and I’m not sure why he added the call to pasynManager->registerInterruptUser for the asynOctet interface initialization, but not for the other interfaces.
These are all the place in asyn itself where pasynOctetBase->initialize() is called.
./testApp/src/addrChangeDriver.c:    status = pasynOctetBase->initialize(portName,&paddrChangePvt->octet,
./testApp/src/addrChangeDriver.c-        0,0,0);
./testApp/src/echoDriver.c-    if(multiDevice) {
./testApp/src/echoDriver.c:        status = pasynOctetBase->initialize(portName,&pechoPvt->octet,0,0,0);
./testApp/src/echoDriver.c-    } else {
./testApp/src/echoDriver.c:        status = pasynOctetBase->initialize(portName,&pechoPvt->octet,1,1,0);
./asyn/drvAsynSerial/drvAsynSerialPort.c:    status = pasynOctetBase->initialize(tty->portName,&tty->octet,
./asyn/drvAsynSerial/drvAsynSerialPort.c-                             (noProcessEos ? 0 : 1),(noProcessEos ? 0 : 1),1);
./asyn/drvAsynSerial/drvAsynSerialPortWin32.c:    status = pasynOctetBase->initialize(tty->portName,&tty->octet,
./asyn/drvAsynSerial/drvAsynSerialPortWin32.c-                             (noProcessEos ? 0 : 1),(noProcessEos ? 0 : 1),1);
./asyn/drvAsynSerial/drvAsynIPServerPort.c:    status = pasynOctetBase->initialize(tty->portName, &tty->octet, 0, 0, 0);
./asyn/drvAsynSerial/drvAsynIPPort.c:    status = pasynOctetBase->initialize(tty->portName,&tty->octet, 0, 0, 1);
./asyn/drvAsynUSBTMC/drvAsynUSBTMC.c:    status = pasynOctetBase->initialize(pdpvt->portName, &pdpvt->asynOctet, 0, 0, 0);
./asyn/asynGpib/asynGpib.c:        status = pasynOctetBase->initialize(portName,&pgpibPvt->octet,0,0,0);
./asyn/interfaces/asynStandardInterfacesBase.c:        status = pasynOctetBase->initialize(portName, &pInterfaces->octet,
./asyn/interfaces/asynStandardInterfacesBase.c-                                            pInterfaces->octetProcessEosIn,
./asyn/interfaces/asynStandardInterfacesBase.c-                                            pInterfaces->octetInterruptProcess);
Note that the final argument is only set to 1 for the drvAsynSerialPort, drvAsynSerialPortWin32, drvAsynIPPort, and optionally for asynStandardInterfacesBase.
Note that asynOctetBase.c also implements a convenience function called callInterruptUser() to actually do the interrupt callbacks.  This is the locations in asyn itself where that function is called:
corvette:~/devel/asyn>find . -name '*.c*' -exec grep -H callInterruptUsers {} \;
./testApp/src/addrChangeDriver.c:    pasynOctetBase->callInterruptUsers(pasynUser,paddrChangePvt->pasynPvt,
./testApp/src/echoDriver.c:    pasynOctetBase->callInterruptUsers(pasynUser,pechoPvt->pasynPvt,
./asyn/asynGpib/asynGpib.c:    pasynOctetBase->callInterruptUsers(pasynUser,pgpibPvt->pasynPvt,
Note that the drvAsynSerialPort and drvAsynIPPort drivers do not call it.  So I am not sure why the interruptProcess flag is set to 1 in those drivers calls to pasynOctetBase->initialize(), since they never actually do interrupt callbacks.
But if you want to try to implement interrupt callbacks in drvAsynIPPort, then most of the groundwork is already done.  You just need to call pasynOctetBase->callInterruptUsers().
-----Original Message-----
Sent: Monday, April 8, 2019 11:15 AM
To: Mark Rivers <[email protected]>; 'Benjamin Franksen' <[email protected]>
Cc: '[email protected]' <[email protected]>
Hi Ben,
Please ignore my previous post.  I just tried adding a call to pasynManager->registerInterruptUser to drvAsynIPPort.c, and I get the same error you do:
diff --git a/asyn/drvAsynSerial/drvAsynIPPort.c b/asyn/drvAsynSerial/drvAsynIPPort.c
index 12c0205..2f85616 100644
--- a/asyn/drvAsynSerial/drvAsynIPPort.c
+++ b/asyn/drvAsynSerial/drvAsynIPPort.c
@@ -1031,7 +1031,14 @@ drvAsynIPPortConfigure(const char *portName,
         ttyCleanup(tty);
         return -1;
+void *octetCallbackPvt;
+status = pasynManager->registerInterruptSource(tty->portName, &tty->octet,
+            &octetCallbackPvt);
+if (status != asynSuccess) {
+        printf("drvAsynIPortConfigure registerInterruptSource failed\n");
+        ttyCleanup(tty);
+        return -1;
      * Register for socket cleanup
drvAsynIPPortConfigure("IPPort", "newport-xps12:5001", 0, 0, 1); IPPort asynManager:registerInterruptSource already registered drvAsynIPortConfigure registerInterruptSource failed
I need to figure this out.  I don't know what code is calling registerInterruptUser for that interface, but it should not be standardInterfacesBase.c.
From: [email protected] <[email protected]> On Behalf Of Mark Rivers via Tech-talk
Sent: Monday, April 8, 2019 10:58 AM
> It is easy to add this capability to drvAsynIPPort. But when I call
> pasynManager->registerInterruptSource I get an error
> "asynManager:registerInterruptSource already registered".
Where are you calling that from?  How did you call it?
> Apparently there is a mechanism in place that generically registers an
> interrupt source for /every/ asynOctet interface (and all other
> standard asyn interfaces, too). This effectively blocks this feature
> for all standard asyn interfaces, so it becomes impossible to add I/O
> Intr support to drvAsynIPPort. The code that calls
> registerInterruptSource in this  generic manner is guarded by an "if
> (octetCanInterrupt)" but I was unable to find out what I should do for this flag to be reset.
> It gets set by the constructor for class asynPortDriver, but I found
> no place where this class actually gets instantiated to an object,
> i.e. a call to the constructor takes place. I find all this pretty confusing and would appreciate hints...
The code that guards with "if (octetCanInterrupt)" is in asynStandardInterfacesBase.c.  That is typically called in the constructor of asynPortDriver.  In the asynPortDriver constructor you pass it a bit mask of interfaces on which your driver will register interrupts.  If you set the asynOctetMask bit in that mask then asynStandardInterfacesBase will call registerInterruptSource on the asynOctet interface.
However, this should be completely irrelevant for the drvAsynIPPort driver, because it does not derive from asynPortDriver and does not use asynStandardInterfacesBase.
Are you sure you were calling pasynManager->registerInterruptSource with a drvAsynIPPort name, and not some other port that derived from asynPortDriver?
From: [email protected] <[email protected]> On Behalf Of Benjamin Franksen via Tech-talk
Sent: Monday, April 8, 2019 9:51 AM
Cc: [email protected]
Subject: Re: drvAsynIPPortConfigure and I/O Intr with asynRecord possible?
Am 04.04.19 um 20:32 schrieb Mark Rivers via Tech-talk:
> The asyn record does NOT work with SCAN=I/O Intr for TCP devices. The
> problem is that drvAsynIPPort does not have a mechanism to do
> callbacks when there is new data, so asyn client needs to poll.  The
> only code I know of that does this is StreamDevice.
"asynManager:registerInterruptSource already registered". Apparently there is a mechanism in place that generically registers an interrupt source for /every/ asynOctet interface (and all other standard asyn interfaces, too). This effectively blocks this feature for all standard asyn interfaces, so it becomes impossible to add I/O Intr support to drvAsynIPPort. The code that calls registerInterruptSource in this generic manner is guarded by an "if (octetCanInterrupt)" but I was unable to find out what I should do for this flag to be reset. It gets set by the constructor for class asynPortDriver, but I found no place where this class actually gets instantiated to an object, i.e. a call to the constructor takes place. I find all this pretty confusing and would appreciate hints...
Cheers
Ben
RE: drvAsynIPPortConfigure and I/O Intr with asynRecord possible? Mark Rivers via Tech-talk
Re: drvAsynIPPortConfigure and I/O Intr with asynRecord possible? Benjamin Franksen via Tech-talk
drvAsynIPPortConfigure and I/O Intr with asynRecord possible? Christoph Schroeder via Tech-talk
Re: drvAsynIPPortConfigure and I/O Intr with asynRecord possible? Mark Rivers via Tech-talk
Prev: RE: drvAsynIPPortConfigure and I/O Intr with asynRecord possible? Mark Rivers via Tech-talk
Next: RE: drvAsynIPPortConfigure and I/O Intr with asynRecord possible? Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 08 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
