1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: drvAsynIPPortConfigure and I/O Intr with asynRecord possible?
From: Benjamin Franksen via Tech-talk <[email protected]>
To: "'[email protected]'" <[email protected]>
Date: Mon, 8 Apr 2019 20:13:12 +0200
[sorry for possible duplicate, forgot to add the list to my reply]
Hi Mark
thanks a lot. As you can see from my other reply I had come to the same
conclusion wrt pasynOctetBase->initialize().
Am 08.04.19 um 18:56 schrieb Mark Rivers:
> So the drvAsynIPPort driver does explicitly ask for
> pasynManager->registerInterruptUser() to be called on the asynOctet
> interface.
Yup.
> Marty wrote this code a long time ago, and I'm not sure why he added
the call to pasynManager->registerInterruptUser for the asynOctet
interface initialization, but not for the other interfaces.>
> Note that the final argument is only set to 1 for the
drvAsynSerialPort, drvAsynSerialPortWin32, drvAsynIPPort, and optionally
for asynStandardInterfacesBase.
> Note that asynOctetBase.c also implements a convenience function
called callInterruptUser() to actually do the interrupt callbacks.  This
is the locations in asyn itself where that function is called:
> corvette:~/devel/asyn>find . -name '*.c*' -exec grep -H
callInterruptUsers {} \;
> ./testApp/src/addrChangeDriver.c:
pasynOctetBase->callInterruptUsers(pasynUser,paddrChangePvt->pasynPvt,
> ./testApp/src/echoDriver.c:
pasynOctetBase->callInterruptUsers(pasynUser,pechoPvt->pasynPvt,
> ./asyn/asynGpib/asynGpib.c:
pasynOctetBase->callInterruptUsers(pasynUser,pgpibPvt->pasynPvt,
> Note that the drvAsynSerialPort and drvAsynIPPort drivers do not call
it.  So I am not sure why the interruptProcess flag is set to 1 in those
drivers calls to pasynOctetBase->initialize(), since they never actually
do interrupt callbacks.
> But if you want to try to implement interrupt callbacks in
drvAsynIPPort, then most of the groundwork is already done.  You just
need to call pasynOctetBase->callInterruptUsers().
I don't think this will work. pasynOctetBase->callInterruptUsers() is
already called by the read method of asynOctetBase. I don't know why it
was done that way but it means I cannot use the existing support for
interrupts in asynOctetBase as that would cause the record(s) to process
in an endless loop. Instead I think I will have to add yet another flag
to drvAsynIPPortConfigure that disables the existing interrupt support
in asynOctetBase (passing 0 as the last argument of
pasynOctetBase->initialize()).
However, having done that I found that things still do not work as I
expected, notably, it looks as if the asynRecord does /not/ issue a read
request if its SCAN field is set to IO Intr. This explains why the
record gets processed endlessly in my test. (If no read is done in
response to the processing, then the poll status isn't reset and the
record gets processed again and again.)
I am not sure how I am supposed to fix that. I can't read inside the
driver's poll loop, because the driver doesn't know how many bytes it
should read and anyway how to pass the result to the record(s). I guess
there is something in the way interrupt processing is designed in asyn
that I am still failing to understand.
Cheers
Ben
Attachment: signature.asc
Description: OpenPGP digital signature
drvAsynIPPortConfigure and I/O Intr with asynRecord possible? Christoph Schroeder via Tech-talk
Re: drvAsynIPPortConfigure and I/O Intr with asynRecord possible? Mark Rivers via Tech-talk
RE: drvAsynIPPortConfigure and I/O Intr with asynRecord possible? Mark Rivers via Tech-talk
Re: drvAsynIPPortConfigure and I/O Intr with asynRecord possible? Benjamin Franksen via Tech-talk
Prev: Re: asynMotor device support and the motor specific driver (asynMotorContorller) Mark Rivers via Tech-talk
Next: Re: asynMotor device support and the motor specific driver (asynMotorContorller) Allan Serra Braga Bugyi via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: RE: drvAsynIPPortConfigure and I/O Intr with asynRecord possible? Mark Rivers via Tech-talk
Next: RE: drvAsynIPPortConfigure and I/O Intr with asynRecord possible? Mark Rivers via Tech-talk
ANJ, 08 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
