After discussing this issue with Ralph I believe that the SVAL field
does not have the PP flag enabled because this would result in records
processing whenever something is writing to the SVAL field - even when
simulation mode is turned off.
So far most users seem to be using simulation mode for _manual_ testing
against a simple model implemented in form of a few additional records
(in this case you usually _pull_ the value through a link). My use case
is slightly different - I want to run _automatic_ tests in Python so I'm
trying to find a simple way of _pushing_ the values into my IOC through
Channel Access. There seem to be two solutions:
1. The Python code writes to the SVAL field and triggers processing by
putting 1 to the PROC field afterwards.
2. In addition to providing a Channel Access client the Python code has
to provide a Channel Access server that the simulation records can pull
their values from.
Thanks for your input!
Martin
Martin Konrad
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
- Record not processing in simulation mode Konrad, Martin via Tech-talk
Re: RES: Pmac Slits giles.knap--- via Tech-talk
Re: RES: Pmac Slits Davis, Mark via Tech-talk
<2019>
2025
2026
Re: Record not processing in simulation mode Ralph Lange via Tech-talk
phoebus evaluation Pierrick M Hanlet via Tech-talk
<2019>
2025
2026
