1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Receiving duplicate monitor values using CA PV Gateway
From: William Layne via Tech-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Date: Fri, 31 May 2019 12:50:05 -0400
I ran two tests with two different PV types, ENUM and LONG. I saw the same behavior as before.
In each test I ran cainfo followed by a camonitor in two different terminals, one directed at the gateway and one at the direct network.
Cainfo for terminals directed at gateway we're using localhost:5064. The cainfo for terminals directed at direct network were using <broadcast>:<random port that ioc was using for tcp>.
Camonitor for terminals directed at the gateway saw duplicate values in camonitor. The terminals directed at the direct network did not.
On Wed, May 29, 2019, 5:59 PM William Layne <[email protected]> wrote:
I left out the other environment variables, but we have EPICS_CA_AUTO_ADDR_LIST and do not see any exceptions or warnings for duplicate IOCs. The logfile for the gateway does have one exception for an unrelated PV (which I know is duplicated between two servers).
I can also confirm that I only see one update on the main network.
When I get in tomorrow, I will run cainfo and camonitor with main network/localhost side by side.
On Wed, May 29, 2019, 5:51 PM Johnson, Andrew N. <[email protected]> wrote:
I agree that setting EPICS_CA_AUTO_ADDR_LIST to NO may be important, but if that's the only issue it should only result in Duplicate PV warnings from camonitor, not in duplicated heartbeat monitor values on the connected channel.
What hostname does the "cainfo" program tell you the PV is found on, and have you been seeing any warnings about duplicate PVs found?
Is your Gateway generating any warnings about duplicate PVs? I suspect they'd go into a logfile but I forget exactly how that is configured.
Can you run camonitor connected to the main network and report whether you see the same duplicate heart-beat values? Repeat that with cainfo too...
- Andrew
On 5/29/19 4:36 PM, Mooney, Tim M. via Tech-talk wrote:
You probably want to set EPICS_CA_AUTO_ADDR_LIST to "NO".  Setting EPICS_CA_ADDR list doesn't restrict attention to the named IP addresses, it just adds them to the list of addresses already found in the init process.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] <[email protected]> on behalf of William Layne via Tech-talk <[email protected]>
Sent: Wednesday, May 29, 2019 4:14 PM
To: Jemian, Pete R.
Cc: [email protected]
Forgot to CC tech talk. Oops.
Yes, we have a few interfaces. I guess it would help to give some info on that. We have it setup with client and gateway both on the same machine:
Client environment settings:
EPICS_CA_ADDR_LIST=localhost; EPICS_CA_SERVER_PORT=5064;
Gateway settings:
-cip <network broadcast>
-sip localhost
IOC settings:
EPICS_CA_ADDR_LIST=<network broadcast>; EPICS_CA_SERVER_PORT=5064;
[Client] <--> ||localhost|| <--> [Gateway] <--> ||network broadcast|| <--> [IOC]
On Wed, May 29, 2019, 4:33 PM Jemian, Pete R. via Tech-talk <[email protected]> wrote:
Does your workstation have two active network interfaces?
Some modern Linux distributions install with a hypervisor that runs the
Linux OS as a guest to that hypervisor.  The hypervisor has a management
network interface and the linux OS has a separate one.  Each are on the
same physical network connection.
On 2019-05-29 3:28 PM, William Layne via Tech-talk wrote:
> Hey all,
> We are seeing duplicate values when first creating our subscriptions
> through the CA Gateway. Is this normal? If not, does anyone know what
> might be causing it?
> Note: We are on EPICS V3.14.12.8 and Gateway 2.1.0
> We see this in our applications and in tools such as camonitor. Here is
> an example output from camonitor, for a heartbeat PV updating every second:
> $ camonitor IOC1_HEARTBEAT
> IOC1_HEARTBEAT               2019-05-29 20:19:51.038659 7651
> IOC1_HEARTBEAT               2019-05-29 20:19:52.038654 7652
> IOC1_HEARTBEAT               2019-05-29 20:19:53.038657 7653
> ^C
> Thanks,
> William 'Casey' Layne
Pete R. Jemian, Ph.D.                 <[email protected]>
Beam line Controls and Data Acquisition (BC, aka BCDA)
Advanced Photon Source,    Argonne National Laboratory
Argonne, IL  60439                    630 - 252 - 3189
       Education is the one thing for which people
          are willing to pay yet not receive.
Complexity comes for free, Simplicity you have to work for.
Re: Receiving duplicate monitor values using CA PV Gateway Johnson, Andrew N. via Tech-talk
Re: Receiving duplicate monitor values using CA PV Gateway Jure Varlec via Tech-talk
Receiving duplicate monitor values using CA PV Gateway William Layne via Tech-talk
Re: Receiving duplicate monitor values using CA PV Gateway Jemian, Pete R. via Tech-talk
Re: Receiving duplicate monitor values using CA PV Gateway William Layne via Tech-talk
Re: Receiving duplicate monitor values using CA PV Gateway Mooney, Tim M. via Tech-talk
Prev: RE: [EXTERNAL] RE: How to share asyn's queue thread among ports? Mark Rivers via Tech-talk
Next: Re: How to share asyn's queue thread among ports? Konrad, Martin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: Receiving duplicate monitor values using CA PV Gateway William Layne via Tech-talk
Next: Re: Receiving duplicate monitor values using CA PV Gateway Johnson, Andrew N. via Tech-talk
ANJ, 01 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
