1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Animatics SmartMotor setup
From: "Davis, Mark via Tech-talk" <[email protected]>
To: Torsten Bögershausen <[email protected]>, Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 18 Jun 2019 17:48:30 +0000
Hi Torsten,
The only issue I am aware of with inserting a Moxa in to the
communications link is the one I discovered a few months ago that had to
do with the fact that the StreamDevice interface doesn't handle
responses that are broken up in to multiple packets when using I/O Intr
mode (see TechTalk messages from 3/18/19 with subject "StreamDevice
Processing Issue")
Unless the SmartMotor controller returns responses > 112 bytes and the
asyn interface has a similar issue with multi-packet responses, I don't
see why a Moxa would cause any problems.  In fact, we have used the
vendor's software just fine with the Moxa configured as a virtual/remote
serial port connected to the motor/controller's RS-232 interface.
Mark Davis NSCL/FRIB Control Systems Software Engineer [email protected]
On 6/18/2019 10:16 AM, Torsten Bögershausen wrote:
> (Re-adding tech-talk)
> Hej Mark & Mark,
> that doesn't seem to be good news -
> The model 1 driver will not work with a Moxa at all.
> Unless I am wrong, we need a model 3 driver (to be written),
> when a controller connected through a Moxa is used.
> /Torsten
> On 18/06/19 16:04, Mark Rivers wrote:
>> Hi Mark,
>> What Torsten says is true for Model 2 and Model 3 motor drivers.
>> However the SmartMotorSrc driver is an old Model 1 driver, so the
>> driver is not derived from asynPortDriver and it only has the single
>> asyn port to the underlying drvAsynIPPort.
>> The OUT field syntax for Model 1 drivers is:
>>          field(OUT,"#C$(C) S$(S) @")
>> where $(C) is the card number, and $(S) is the signal number. So for
>> the first axis on the first controller it would be
>>       field(OUT,  "#C0 S0 @")
>> Mark
>> -----Original Message-----
>> From: [email protected] <[email protected]>
>> On Behalf Of Torsten Bögershausen via Tech-talk
>> Sent: Tuesday, June 18, 2019 6:45 AM
>> To: Mark Davis <[email protected]>; Davis, Mark
>> <[email protected]>; [email protected]
>> Hej Mark,
>> you need 2 asyn ports, one for the motorRecord to talk to your
>> "Animatics SmartMotor" asynMotorDriver.
>> The second one to let the "Animatics SmartMotor" asynMotorDriver talk
>> to the real hardware.
>> We call them "MCU1" and "MC_CPU1", better suggestions are welcome.
>> A simplified setup is here:
>> ## The db file:
>> record(motor,"$(PREFIX)$(MOTOR_NAME)")
>>     field(DESC,"$(DESC)")
>>     field(DTYP,"asynMotor")
>>     field(OUT,"@asyn($(MOTOR_PORT),$(AXIS_NO))")
>> ##st.cmd
>> epicsEnvSet("ASYN_PORT",     "MC_CPU1")
>> epicsEnvSet("MOTOR_NAME",    "IOC:m1")
>> epicsEnvSet("MOTOR_PORT",    "MCU1")
>> epicsEnvSet("AXIS_NO",       "1")
>> drvAsynIPPortConfigure("$(ASYN_PORT)","$(IPADDR):$(IPPORT)",0,0,0)
>> EthercatMCCreateController("$(MOTOR_PORT)", "$(ASYN_PORT)",
>> "$(NUMAXES)", "200", "1000")
>> EthercatMCCreateAxis("$(MOTOR_PORT)", "$(AXIS_NO)",)
>> I hope that hopes a little bit.
>> /Torsten
>> On 18/06/19 13:11, Davis, Mark via Tech-talk wrote:
>>> Can anyone provide an example of how to setup and use an Animatics
>>> SmartMotor?
>>>   From what I could figure out looking at the code, I expect it is
>>> something along these lines:
>>> # For a connection via a Moxa Ethernet-to-serial adapter:
>>> drvAsynIPPortConfigure("TapeStation", "192.168.137.99:4001")
>>> # SmartMotorSetup(maxCtlrCount, pollRate) SmartMotorSetup(1, 5)
>>> # SmartMotorConfig(cardNum, "asynPortName") SmartMotorConfig(0,
>>> "TapeStation")
>>> And then the motor record would look something like this:
>>> record(motor, "MyMotor")
>>>     field(DTYP, "SmartMotor")
>>>     field(OUT,  "@0 TapeStation ????")
>>> Is that even close?  The one I am most unsure of is what to use for
>>> the OUT value in the motor record.
>>> Mark Davis
>>> NSCL/FRIB
Animatics SmartMotor setup Davis, Mark via Tech-talk
Re: Animatics SmartMotor setup Torsten Bögershausen via Tech-talk
Prev: Re: Animatics SmartMotor setup Torsten Bögershausen via Tech-talk
Next: Re: Animatics SmartMotor setup Davis, Mark via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Animatics SmartMotor setup Mark Rivers via Tech-talk
ANJ, 18 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
