1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Animatics SmartMotor setup
From: "Davis, Mark via Tech-talk" <[email protected]>
To: "Peterson, Kevin M." <[email protected]>, "Davis, Mark" <[email protected]>, Torsten Bögershausen <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 18 Jun 2019 17:57:35 +0000
Hi Kevin,
Thank you (and everyone else) for all the info.
Not sure when I can get my hands on the actual motor again, but I will
be giving this a try as soon as I can.  At the very least I should be
able to get an IOC to spit requests out a serial port on a Moxa.
Mark Davis NSCL/FRIB Control Systems Software Engineer [email protected]
On 6/18/2019 12:36 PM, Peterson, Kevin M. wrote:
> On 6/18/19 10:29 AM, Davis, Mark via Tech-talk wrote:
>> Let me back up a little and give some more specifics that might help
>> clarify things:
>> Here is what we are using:
>>      * An Animatics SmartMotor model SM3416D-PLS (a combination
>> motor+controller).  The interface to the controller is a serial RS-232
>> connection.
>>      * A single port Moxa Serial/Ethernet convertor connected to the
>> serial port on the motor/controller.
>>      * Version 6.9 of the motor module
>>      * The driver in the SmartMotorSrc subdirectory of the motor module
>> <snip> >
>> As near as I can tell so far my example is correct.  I just don't know
>> what the driver is expecting for the contents of the OUT field in the
>> motor record.
> Mark Rivers already provided the correct OUT field in the message he
> forwarded to this thread.  I would just like to add the following info.
> Now that the motor module has been split into multiple repositories, the
> SmartMotor module contains an example IOC:
> https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_epics-2Dmotor_motorSmartMotor_tree_master_iocs_smartMotorIOC&d=DwIGaQ&c=nE__W8dFE-shTxStwXtp0A&r=D7ZiziuMQuq40HlGYOZPBg&m=PLRQs337cbj5iYY7P6hTIwSKR143RRyl2pxLgFfSH8I&s=R5g8lDMJhzOn5c3YycvXcweBysIumYlxb8ey5qtt6Bc&e=
> Controllers with model-1 drivers, like the SmartMotor controller,
> usually load motor.db:
> https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_epics-2Dmotor_motorSmartMotor_blob_ee30ba9cc44761a0cd28e22c9b48903368417096_iocs_smartMotorIOC_iocBoot_iocSmartMotor_SmartMotor.substitutions-23L1&d=DwIGaQ&c=nE__W8dFE-shTxStwXtp0A&r=D7ZiziuMQuq40HlGYOZPBg&m=PLRQs337cbj5iYY7P6hTIwSKR143RRyl2pxLgFfSH8I&s=8TxvBFqxZ8QSxiCnD32Nejopq506GOXC6CZz-ZN6kcU&e=
> Which requires C and S macros for the OUT field:
> https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_epics-2Dmodules_motor_blob_4aa7d84d8a63afb500f05c72e98aa6335cda93b9_motorApp_Db_motor.db-23L16&d=DwIGaQ&c=nE__W8dFE-shTxStwXtp0A&r=D7ZiziuMQuq40HlGYOZPBg&m=PLRQs337cbj5iYY7P6hTIwSKR143RRyl2pxLgFfSH8I&s=SQmvQqMZfkM-dB3HmScM4unHf2XlqYCetwPsiITwe1A&e=
> Kevin
Animatics SmartMotor setup Davis, Mark via Tech-talk
Re: Animatics SmartMotor setup Torsten Bögershausen via Tech-talk
Re: Animatics SmartMotor setup Davis, Mark via Tech-talk
Re: Animatics SmartMotor setup Peterson, Kevin M. via Tech-talk
Prev: Re: Animatics SmartMotor setup Davis, Mark via Tech-talk
Next: EPICS driver for Mesytec MCPD-8 zhi.qiu--- via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Animatics SmartMotor setup Peterson, Kevin M. via Tech-talk
Next: Re: Animatics SmartMotor setup Torsten Bögershausen via Tech-talk
ANJ, 19 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
