1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Installing 'std' module to use epid record
From: "Mooney, Tim M. via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, Christopher Herrmann <[email protected]>
Date: Thu, 27 Jun 2019 20:35:53 +0000
There several ways to get the epid record without including stuff you don't want:
  1. You could build the record directly into your application.  The epid record itself doesn't need anything but base.  devEpidFast needs asyn, but you don't have to build devEpidFast to use the epid record.
  2. If you want to start with the std module, but don't want to include ASYN or SNCSEQ, just comment them out of std/configure/RELEASE, try to build, and comment anything that fails to build out of std/stdApp/src/Makefile and out of std/stdApp/src/stdSupport.dbd.  You will want to "make clean uninstall" after modifying Makefile or any .dbd file.
  3. You can use std as it is, if you also build asyn and seq.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: [email protected] <[email protected]> on behalf of Christopher Herrmann via Tech-talk <[email protected]>
Sent: Thursday, June 27, 2019 1:52 PM
To: [email protected]
Subject: Installing 'std' module to use epid record
Hello,
I am very much just getting a handle on EPICS as a whole. This may seem like a trivial question but after trying for a number of hours I have not gotten any closer to my goal.
I am currently building a device that needs precise temperature control and I would like to implement PID control into my IOC. I would like to use the "epid" record but I cannot seems to get it installed. Ideally, I would like to keep the whole system relatively lightweight and install only the modules and their dependencies, rather than the whole synApps package.
How could I go about doing this?
Thank you,
~ Chris
Installing 'std' module to use epid record Christopher Herrmann via Tech-talk
Prev: Installing 'std' module to use epid record Christopher Herrmann via Tech-talk
Next: Re: [EXTERNAL] Beckhoff BK9000 support survey Dunning, Michael via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: procServ v2.8.0 available Ralph Lange via Tech-talk
ANJ, 28 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
