1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Phoebus Radiobutton cannot set mbbi record
From: Florian Feldbauer via Tech-talk <[email protected]>
To: "Kasemir, Kay" <[email protected]>, "'[email protected]'" <[email protected]>
Date: Mon, 12 Aug 2019 17:16:55 +0200
Hey,
ok, now both work if I also remove "pva://" from the PV name.....
So somehow checkbox and radiobutton do not work with PVaccess, or do I have to use ".VAL" explicitly in this case?
But with DTYP set to "Soft Channel" the RVAL of the mbbi records is not set, so I have to find another solution.
For further processing I the numbers from the xxVL fields.
Cheers,
Florian
On 8/12/19 3:05 PM, Kasemir, Kay wrote:
..for the bi record / checkbox I do not have set DTYP
  and still it only works by using ".RVAL" in the record name.
Cannot reproduce.
Tried this record with both R3.14.12.6 and R7.0.2.2 softIoc:
record( bi, "bandgap1")
    field( ZNAM, "disabled" )
    field( ONAM, "active" )
Adding a 'Check Box' widget, enter bandgap1 as PV name, leaving rest on default, and it simply works.
-Kay
Dr. Florian Feldbauer
Ruhr-Universität Bochum
Experimentalphysik I AG
Universitätsstr. 150
Fach-Nr. 125
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
Re: [EXTERNAL] Phoebus Radiobutton cannot set mbbi record Kasemir, Kay via Tech-talk
Phoebus Radiobutton cannot set mbbi record Florian Feldbauer via Tech-talk
Re: [EXTERNAL] Phoebus Radiobutton cannot set mbbi record Florian Feldbauer via Tech-talk
Prev: Fwd: Re: Fwd: cross-compiling (kind of) with Buildroot Pierrick M Hanlet via Tech-talk
Next: Re: Fwd: Re: Fwd: cross-compiling (kind of) with Buildroot Jeong Han Lee via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [EXTERNAL] Phoebus Radiobutton cannot set mbbi record Kasemir, Kay via Tech-talk
Next: Re: [EXTERNAL] Phoebus Radiobutton cannot set mbbi record Kasemir, Kay via Tech-talk
ANJ, 12 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
