1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asyn R4-36 available
To: Abdalla Ahmad <[email protected]>
Date: Wed, 21 Aug 2019 12:04:28 +0000
> Can you please explain in more details what the parseAsynUser method is used for?
It is a convenience method that parses the pasynUser and returns the pasynUser->reason, the asyn address, and the parameter name encoded  by that pasynUser.  So it combines several calls into one, which is useful because this needs to be done frequently, i.e. in all of the derived methods writeInt32, readInt32, writeFloat64, readFloat64, etc.
This is the code:
asynStatus asynPortDriver::parseAsynUser(asynUser *pasynUser, int *reason, int *address, const char **paramName)
    //static const char *functionName = "parseAsynUser";
    asynStatus status;
    *reason = pasynUser->reason;
    status = this->getAddress(pasynUser, address);
    if (status) return status;
    status = this->getParamName(*reason, paramName);
    return status;
Sent: Wednesday, August 21, 2019 3:28 AM
To: Mark Rivers
Cc: [email protected]
Subject: RE: asyn R4-36 available
Hello Mark
Many thanks on your efforts with the asyn driver. Can you please explain in more details what the parseAsynUser method is used for?
Best Regards,
Abdalla.
From: [email protected] <[email protected]> On Behalf Of Mark Rivers via Tech-talk
Sent: Friday, August 09, 2019 2:03 AM
To: '[email protected]' <[email protected]>
Subject: asyn R4-36 available
Folks,
asyn R4-36 is now available.
asyn is available on github here:
https://github.com/epics-modules/asyn
tar and zip files are available here:
https://github.com/epics-modules/asyn/releases
Soon you will be able to find links to the new documentation and release notes here:
http://www.aps.anl.gov/epics/modules/soft/asyn
These are from the R4-36 release notes:
- asynManager
  - Improved debugging output when scheduling queue request timeout.
- drvAsynIPPort
  - Improved diagnostic messages.
- asynPortDriver
  - Added new parseAsynUser() method. Changed all readXXX and writeXXX methods to use this, rather than getAddress().
  - Use asynPortDriver::getAddress() in callback functions, rather than pasynManager::getAddress(). This allows the getAddress() to be overridden in derived classes.
  - Fix to prevent a potentially locked mutex from being destroyed, as well as use-after-free bugs on other members of asynPortDriver. Thanks to Martin Konrad for this.
- asynInterposeDelay, asynInteposeEcho
  - Fixes to compile on Visual Studio 2010.
asyn R4-36 available Mark Rivers via Tech-talk
RE: asyn R4-36 available Abdalla Ahmad via Tech-talk
Prev: EPICS support for HORIBA iHR320 monochromator ? Heinz Junkes via Tech-talk
Next: pvput and enum (EPICS 7.0.3) Alfio Rizzo via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: RE: asyn R4-36 available Abdalla Ahmad via Tech-talk
Next: areaDetector R3-7 released Mark Rivers via Tech-talk
ANJ, 21 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
