Thank you Mark,
Would you kindly share with me the settings on your terminal server?
Since the IOC runs without problems from a terminal; since
I have several soft IOCs running from procServ the same host computer on
different ports; and since this IOC is the only one
with a terminal server, I've reason to believe that the terminal
server's settings may be the culprit.
Thank you,
Pierrick
The terminal server that I am using
On 11/2/19 4:23 PM, Mark Rivers wrote:
> Hi Pierrick,
> I just tested the following configuration:
> Keithley 2700, RS-232
> Digi One SP Ethernet to serial (terminal server)
> EPICS base 7.0.3.1
> procServ 2.7.0
> Running an EPICS application built with the latest versions of asyn and ip (for Keithley 2700 support).
> It works fine, I do not get the error you do.
> I also tested with base 7.0.2 and it works as well, so I don't think your problem is the version of base.
> I suspect something else is wrong in your application.
> Mark
> ________________________________
> From: Mark Rivers
> Sent: Thursday, October 31, 2019 9:11 PM
> To: Pierrick M Hanlet
> Cc: Michael Davidsaver; [email protected]
> Subject: Re: No TCP server started
> Hi Pierrick,
> We routinely run linux-x86_64 IOCs that talk to Keithley 2700 multimeters using Ethernet terminal servers and running under procServ. These are running with base 7.0.2. I can test tomorrow with 7.0.3.
> Mark
> Sent from my iPhone
>> On Oct 31, 2019, at 4:26 PM, Pierrick M Hanlet via Tech-talk <[email protected]> wrote:
>> Here's what I get from a stripped down epicsEnvShow.
>> EPICS_PATH=/home/epics/epicsDEV
>> EPICS_IOCTOPS=/home/epics/epicsDEV/iocTops
>> EPICS_PVA_ADDR_LIST=131.225....
>> EPICS_BASE=/home/epics/epicsDEV/base
>> EPICS_PVA_AUTO_ADDR_LIST=NO
>> EPICS_EXTENSIONS=/home/epics/epicsDEV/Extensions
>> EPICS_CA_AUTO_ADDR_LIST=NO
>> EPICS_HOST_ARCH=linux-x86_64
>> EPICS_CONFIG=/home/epics/epicsDEV/Config
>> EPICS_CA_ADDR_LIST=131.225....
>> EPICS_SOFTWARE=/home/epics/epicsDEV/Software
>> EPICS_CA_MAX_ARRAY_BYTES=131072
>> EPICS_SUPPORT=/home/epics/epicsDEV/Support
>> EPICS_VERSION_MAJOR=7
>> EPICS_VERSION_MIDDLE=0
>> EPICS_VERSION_MINOR=3
>> EPICS_VERSION_PATCH=0
>> EPICS_VERSION_SNAPSHOT=
>> EPICS_VERSION_SITE=
>> EPICS_VERSION_SHORT=7.0.3
>> EPICS_VERSION_FULL=7.0.3
>> EPICS_IOC_OWNER=hanlet
>> EPICS_IOC_GROUP=FE_group
>> EPICS_IOC_LOCATION=???
>>> On 10/31/19 9:19 AM, Michael Davidsaver wrote:
>>> "CAS: No TCP server started" means that the CA server configuration, when applied
>>> to the host system, has resulted in no TCP server sockets being created. So the
>>> CA server would be inoperative. The lack of previous errors is strange.
>>> I'd expect to see eg. some "bind error"s shown.
>>> What $EPICS_* environment variables are set?
>>>> On 10/29/19 10:25 AM, Pierrick M Hanlet via Tech-talk wrote:
>>>> Hi,
>>>> I've several soft IOCs happily running 7.0.3 on linux-x86_64 on different ports. However,
>>>> I have a new one which is connected to a ethernet<->serial converter which runs
>>>> without issue from a terminal, but fails with "No TCP server started" when started
>>>> from procServ. A similar message was reported to core-talk by Heinz Junkes when
>>>> using 3.16.0.1-DEV-fhi.
>>>> This has nothing to do with my databases, as I have them commented out:
>>>> My startup command is:
>>>> epics:~/epicsDEV/Config/ProcLauncher> procServ -i ^D^C --killsig 15 --logfile /home/epics/epicsDEV/ioc_logs/Keithley2700_2019_10_29__11_59_38.log --name Keithley2700 --pidfile /home/epics/.PROCSERV_CMD_1572368378214534208 --quiet 7718 /home/epics/epicsDEV/iocTops/Multimeter/iocBoot/iocKeithley2700/st.cmd
>>>> And the resulting log file has:
>>>> @@@ Restarting child "Keithley2700"
>>>> @@@ (as /home/epics/epicsDEV/iocTops/Multimeter/iocBoot/iocKeithley2700/st.cmd)
>>>> @@@ The PID of new child "Keithley2700" is: 7855
>>>> #!../../bin/linux-x86_64/Keithley2700
>>>> ## You may have to change Keithley2700 to something else
>>>> ## everywhere it appears in this file
>>>> < envPaths
>>>> epicsEnvSet("IOC","iocKeithley2700")
>>>> epicsEnvSet("TOP","/home/epics/epicsDEV/iocTops/Multimeter")
>>>> epicsEnvSet("EPICS_BASE","/home/epics/epicsDEV/base")
>>>> epicsEnvSet("EPICS_SUPPORT","/home/epics/epicsDEV/Support")
>>>> epicsEnvSet("ASYN","/home/epics/epicsDEV/Support/asyn")
>>>> epicsEnvSet("CALC","/home/epics/epicsDEV/Support/calc")
>>>> epicsEnvSet("STREAM","/home/epics/epicsDEV/Support/StreamDevice")
>>>> epicsEnvSet("ALIVE","/home/epics/epicsDEV/Support/alive")
>>>> epicsEnvSet("KEITHLEY","/home/epics/epicsDEV/Support/Keithley")
>>>> epicsEnvSet("EPICS_IOC_OWNER","hanlet")
>>>> epicsEnvSet("EPICS_IOC_GROUP","FE_group")
>>>> epicsEnvSet("EPICS_IOC_LOCATION","???")
>>>> cd "/home/epics/epicsDEV/iocTops/Multimeter"
>>>> ## Register all support components
>>>> dbLoadDatabase "dbd/Keithley2700.dbd"
>>>> Keithley2700_registerRecordDeviceDriver pdbbase
>>>> ## Configure IP port
>>>> drvAsynIPPortConfigure("keithley","131.225.138.251:10002",0,0,0)
>>>> ## Debuggin
>>>> asynSetTraceIOMask("keithley",0,2)
>>>> asynSetTraceMask("keithley",0,9)
>>>> ## Load record instances
>>>> #dbLoadRecords("db/Keithley2700.db")
>>>> #dbLoadRecords("db/alive.db")
>>>> #dbLoadRecords("db/watcher.db")
>>>> ## Protocol file
>>>> epicsEnvSet("STREAM_PROTOCOL_PATH","/home/epics/epicsDEV/Support/Keithley/Keithley2700App/protocol")
>>>> ## Start IOC
>>>> cd "/home/epics/epicsDEV/iocTops/Multimeter/iocBoot/iocKeithley2700"
>>>> iocInit
>>>> Starting iocInit
>>>> ## EPICS R7.0.3
>>>> ## EPICS Base built Oct 23 2019
>>>> Thread _main_ (0x1b50450) can't proceed, suspending.
>>>> Dumping a stack trace of thread '_main_':
>>>> [ 0x7fc82a4fe25b]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libCom.so.3.17.5(epicsStackTrace+0x4b)
>>>> [ 0x7fc82a4ee818]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libCom.so.3.17.5(cantProceed+0xb8)
>>>> [ 0x7fc82a9f4be9]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libdbCore.so.3.17.4(rsrv_init+0xf69)
>>>> [ 0x7fc82a9e07ab]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libdbCore.so.3.17.4(dbInitServers+0x1b)
>>>> [ 0x7fc82a9f19de]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libdbCore.so.3.17.4(iocBuild+0x2e)
>>>> [ 0x7fc82a9f1b89]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libdbCore.so.3.17.4(iocInit+0x9)
>>>> [ 0x7fc82a4e9555]: /home/epics/epicsPRO/base-7.0.3/lib/linux-x86_64/libCom.so.3.17.5(iocshBody+0xb15)
>>>> [ 0x407bb2]: ../../bin/linux-x86_64/Keithley2700(main+0x12)
>>>> [ 0x7fc828d64545]: /lib64/libc.so.6(__libc_start_main+0xf5)
>>>> [ 0x407bfd]: ../../bin/linux-x86_64/Keithley2700(_start+0x29)
>>>> Any ideas? If helpful, the device is a Lantronix UDS2100 serial-to-ethernet converter; though I
>>>> don't know if that matters.
>>>> Thanks,
>>>> Pierrick
>>>> Pierrick Hanlet
>>>> Fermi National Accelerator
>>>> Accelerator Front End Controls
>>>> +1-630-840-5555 -- lab
>>>> +1-312-687-4980 -- mobile
>>>> "Whether you think you can or think you can't, you're right" -- Henry Ford
>> Pierrick Hanlet
Pierrick Hanlet
- RE: No TCP server started Mark Rivers via Tech-talk
- No TCP server started Pierrick M Hanlet via Tech-talk
- Re: No TCP server started Michael Davidsaver via Tech-talk
- Re: No TCP server started Pierrick M Hanlet via Tech-talk
- Re: No TCP server started Mark Rivers via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
