1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: No TCP server started
From: Pierrick M Hanlet via Tech-talk <[email protected]>
Date: Mon, 4 Nov 2019 14:20:39 +0000
Hi Ralph,
Yes, both startup scripts point to the same script which defines my
environment
variables.
Pierrick
On 11/4/19 2:20 AM, Ralph Lange via Tech-talk wrote:
> Do you use the same settings for the EPICS_CA_* variables when you're
> running the IOC successfully from a terminal?
> Cheers,
> ~Ralph
Pierrick Hanlet
Fermi National Accelerator
Accelerator Front End Controls
+1-630-840-5555 -- lab
+1-312-687-4980 -- mobile
"Whether you think you can or think you can't, you're right" -- Henry Ford
No TCP server started Pierrick M Hanlet via Tech-talk
Re: No TCP server started Michael Davidsaver via Tech-talk
Re: No TCP server started Pierrick M Hanlet via Tech-talk
Re: No TCP server started Mark Rivers via Tech-talk
RE: No TCP server started Mark Rivers via Tech-talk
Re: No TCP server started Ralph Lange via Tech-talk
Prev: Re: execute python from st.cmd Bruno Martins via Tech-talk
Next: Re: EPICS Base-3.15.7 and EPICS 7.0.3.1 Released Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: No TCP server started Ralph Lange via Tech-talk
Next: counter enum riz via Tech-talk
ANJ, 04 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
