Subject: Re: Connection Timeout Using Asyn and StreamDevice with Ethernet Device
To: "Peterson, Kevin M." <[email protected]>, "Rivers, Mark L." <[email protected]>
Date: Thu, 2 Jan 2020 14:12:51 +0000
Mark and Kevin,
I wanted to thank you for your suggestions. Both came in handy.
Using Wireshark and tcpdump I was able to see several TCP Acknowledgements and TCP Retransmissions from the power meter. After five retransmissions the telnet connection would close. I contacted Mini-Circuits with this information and they were very accommodating. They developed new firmware which includes improvements to the device's networking and better error handling during interrupted communication. The firmware version can be downloaded here: http://yoni-il.minicircuits.com/download/PWR_8P_RC_Firm_A3.zip I also had to increase my ASYN/StreamDevice timeout to 2 seconds to avoid timing out on the EPICS side.
Thanks again and Happy New Year!
Kyle
Sent: Thursday, November 7, 2019 4:27 PM
To: Kyle Hesse <[email protected]>; Rivers, Mark L. <[email protected]>
Cc: [email protected] <[email protected]>
Subject: [EXTERNAL] Re: Connection Timeout Using Asyn and StreamDevice with Ethernet Device
I would suggest asking the manufacturer of the power meter how the meter
behaves when a client disconnects suddenly.
I've seen a problem like this in the past with a piezo controller that
would only connect to an EPICS IOC once for each power-cycle.  The
solution was a firmware upgrade that sent TCP keepalive packets and
terminated the connection after a TCP keepalive timeout.
Kevin
On 11/7/19 2:39 PM, Kyle Hesse via Tech-talk wrote:
> Yes, a restart of the IOC does not reconnect. I have to cycle power.
> AutoConnect does try its best though.
Prev: Re: Ethernet question Bruno Martins via Tech-talk
Next: Re: Sphinx/CSS question Matt Newville via Tech-talk
Prev: RE: Ethernet to RS-232 Danfysik supply connection issues Kathryn Baker - UKRI STFC via Tech-talk
Next: Epics 7.0.4 java release Shroff, Kunal via Tech-talk
