1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: Killing caRepeater on Windows 10
To: Matt Newville <[email protected]>
Date: Tue, 14 Jan 2020 17:31:54 +0000
I just did an experiment with 4 different versions of caget.  For each experiment I did the following:
-          Kill the existing caRepeater task
-          Run caget
-          See if caRepeater.exe showed up in Task Manager Details tab.
The versions of caget I tested were
7.0.3.1
3.15.5
3.14.12.6
The version that comes with the most recent EPICS Windows Tools, caRepeater.exe dated 7/8/2014.
Of these only the EPICS Windows Tools version produced a caRepeater.exe that appeared in the Windows 10 Task Manager.  All of the others started caRepeater, but it was not visible in Task Manger.
Another question might be what version of caRepeater is actually run.  I assume this is the first one found in the PATH.
J:\epics\devel\dxp>where carepeater
H:\epics\base\bin\windows-x64-static\caRepeater.exe
C:\Program Files\caQTDM\bin\windows-x64\caRepeater.exe
H:\epics\base\bin\windows-x64-static is a soft link to base-7.0.3.1, so that should be the version of caRepeater it is running.
Sent: Tuesday, January 14, 2020 10:16 AM
Cc: Engbretson, Mark S. <[email protected]>; [email protected]
Subject: Re: Killing caRepeater on Windows 10
I do see caRepeater.exe appear in the Details tab of Task Manager on Windows 10 once a real CA connection is begun.
--Matt Newville
RE: Killing caRepeater on Windows 10 Mark Rivers via Tech-talk
Re: Killing caRepeater on Windows 10 Žiga Oven via Tech-talk
Re: Killing caRepeater on Windows 10 Mark Rivers via Tech-talk
Re: Killing caRepeater on Windows 10 Matt Newville via Tech-talk
Prev: RE: scaler record simulation Mark Rivers via Tech-talk
Next: RE: Killing caRepeater on Windows 10 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: Killing caRepeater on Windows 10 Matt Newville via Tech-talk
