1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: Getting images from area detector plugins
To: 'Randall Cayford' <[email protected]>
Date: Fri, 24 Jan 2020 20:26:12 +0000
Ø  That’s where I’m lost.  I think you are saying that there is a channel access PV that contains the JPEG bytes.
Ø  If so, which PV is it?  I’m not sure what waveform record I’m looking for.
It will be $(P)$(R)ArrayData, where $(P) is the prefix for that detector and $(R) is the prefix for the NDPluginStdArrays plugin.
For example with the standard setup of the areaDetector ADSimDetector this command reads the first 100 bytes from the NDPluginStdArrays plugin waveform record.
corvette:ADSimDetector/simDetectorApp/op>caget -#100 13SIM1:image1:ArrayData
13SIM1:image1:ArrayData 100 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 -128 -127 -126 -125 -124 -123 -122 -121 -120 -119 -118 -117 -116 -115 -114 -113 -112 -111 -110 -109 -108 -107 -106 -105 -104 -103 -102 -101 -100 -99 -98 -97 -96 -95 -94 -93 -92 -91 -90 -89 -88 -87 -86 -85 -84 -83 -82 -81 -80 -79 -78 -77 -76 -75 -74 -73 -72 -71 -70 -69 -68 -67 -66 -65 -64 -63 -62 -61 -60 -59 -58 -57 -56 -55 -54 -53 -52 -51 -50 -49 -48 -47
This does not currently handle compressed data, but I will make changes today so that it will.
Sent: Friday, January 24, 2020 2:03 PM
Cc: Wang Xiaoqiang <[email protected]>; [email protected]
Subject: Re: Getting images from area detector plugins
On Jan 24, 2020, at 11:49 AM, Mark Rivers <[email protected]> wrote:
With Channel Access the waveform record will contain just the JPEG bytes, as will the “value” member of the NTNDArray structure.
That’s where I’m lost.  I think you are saying that there is a channel access PV that contains the JPEG bytes.  If so, which PV is it?  I’m not sure what waveform record I’m looking for.
Thanks.
Randall
CAS-client thread issues in areaDetector IOC Wlodek, Jakub via Tech-talk
RE: CAS-client thread issues in areaDetector IOC Mark Rivers via Tech-talk
Re: CAS-client thread issues in areaDetector IOC Wlodek, Jakub via Tech-talk
Re: CAS-client thread issues in areaDetector IOC Michael Davidsaver via Tech-talk
Getting images from area detector plugins Randall Cayford via Tech-talk
RE: Getting images from area detector plugins Mark Rivers via Tech-talk
Re: Getting images from area detector plugins Wang Xiaoqiang via Tech-talk
Re: Getting images from area detector plugins Mark Rivers via Tech-talk
Re: Getting images from area detector plugins Randall Cayford via Tech-talk
Prev: Re: Getting images from area detector plugins Randall Cayford via Tech-talk
Next: RE: possibility of using areaDetector to drive Varax 4343 detector Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: RE: Getting images from area detector plugins Mark Rivers via Tech-talk
