Subject: RE: possibility of using areaDetector to drive Varax 4343 detector
To: "'Miceli, Antonino'" <[email protected]>, "ChenZhang@Gmail" <[email protected]>
Date: Fri, 24 Jan 2020 21:14:19 +0000
So it appears they have 2 different packages for the XRD1621 etc. vs the XRD 4343.  They are both called XISL.  If they only differ in the Windows drivers then ADPerkinElmer should work.  But if they differ in the library API then ADPerkinElmer would need changes.
Sent: Friday, January 24, 2020 1:59 PM
To: Mark Rivers <[email protected]>; ChenZhang@Gmail <[email protected]>
Cc: [email protected]
Subject: Re: possibility of using areaDetector to drive Varax 4343 detector
Ted Lutzel <[email protected]>  told me this about their software:
Use this link for the XRD 4343CT detectors:
https://vareximagpub.sharepoint.com/:u:/g/EakLzPppP_5GlNMaKft2Kh4BJ32zG-Ma8gfBHsGA5fPb2Q
Use this link for the XRD 0820, XRD0822, XRD 1622, XRD 1611, and XRD 1621 detectors:
https://vareximagpub.sharepoint.com/:f:/g/En2Fm4JX9t9Kkyo5ifUvmGABuUhkmHNCNiDWH64QEEL8sQ
Nino
From: Tech-talk <[email protected]> on behalf of ChenZhang@Gmail via Tech-talk <[email protected]>
Sent: Friday, January 24, 2020 1:54 PM
To: Rivers, Mark L. <
[email protected]>
Cc:
[email protected] <[email protected]>
The vendor software is called XIS (Windows), which allows us to write frames to a buffer, then manually save them to disk.  We will contact the vendor to confirm if a different SDK is used for this new model.
Chen
> On Jan 24, 2020, at 1:41 PM, Mark Rivers <
[email protected]> wrote:
>> I was wondering if it would be possible to use areaDetector to drive Varax 4343.
> Do you know what software is provided with that detector?  There are 2 areaDetector drivers for Varax flat panel detectors, ADPerkinElmer and ADDexela.  Does the 4343 use the same SDK as either of these?
> Mark
> -----Original Message-----
> From: Tech-talk <
[email protected]> On Behalf Of ChenZhang@Gmail via Tech-talk
> Sent: Friday, January 24, 2020 1:26 PM
> To:
[email protected]
> Subject: possibility of using areaDetector to drive Varax 4343 detector
> Hi All,
> We are trying to test the hardware triggering of Varax 4343 for HT-HEDM, and the vendor software does not support directly dumping frames from buffer to disk.  I was wondering if it would be possible to use areaDetector to drive Varax 4343.
> Best,
> Chen
> Chen Zhang
> Postdoc Researcher
> Department of Mechanical Engineering
> Colorado School of Mines
> 1500 Illinois Street Golden, CO 80401
[email protected]
[email protected]
possibility of using areaDetector to drive Varax 4343 detector ChenZhang@Gmail via Tech-talk
RE: possibility of using areaDetector to drive Varax 4343 detector Mark Rivers via Tech-talk
Re: possibility of using areaDetector to drive Varax 4343 detector ChenZhang@Gmail via Tech-talk
Re: possibility of using areaDetector to drive Varax 4343 detector Miceli, Antonino via Tech-talk
Prev: RE: Getting images from area detector plugins Mark Rivers via Tech-talk
Next: Re: CAS-client thread issues in areaDetector IOC Michael Davidsaver via Tech-talk
Prev: Re: possibility of using areaDetector to drive Varax 4343 detector Miceli, Antonino via Tech-talk
Next: caQtDM on android Mezger Anton Christian (PSI) via Tech-talk
