1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: SNCSEQ Error Windows
From: Benjamin Franksen via Tech-talk <[email protected]>
To: tech-talk <[email protected]>
Date: Thu, 13 Feb 2020 15:08:46 +0100
Am 12.02.20 um 02:31 schrieb Freddie Akeroyd - UKRI STFC via Tech-talk:
> If I unpack seq 2.2.8 into the epics-base/modules area I get the same
> build error as mentioned for the example with epics 7 (master). If I
> move the seq directory to outside of the modules area, then
> everything works fine.
> What I think is happening is that when seq 2.2.8 is placed in the
> epics-base/modules area its binaries are installed into
> epics-base/bin rather than seq/bin. The .st/.stt compile rules for
> the seq assume the snc executable is installed in $(SNCSEQ)/bin and
> so they then fail.
> The CONFIG_SITE.local  in epics-base/modules sets INSTALL_LOCATION to
> epics-base/bin, in seq 2.2.8 its CONFIG_SITE includes $(TOP)/../
> CONFIG_SITE.local whereas in 2.2.5 this is not done, which I suspect
> is why seq 2.2.5 works ok.
Thanks for this analysis! I did not realise the OP had unpacked seq
under epics-base/modules. I doubt this is an "officially supported" way
to build support modules. Perhaps a warning should be issued if someone
tries that.
Cheers
Ben
Attachment: signature.asc
Description: OpenPGP digital signature
SNCSEQ Error Windows Hetz, Benjamin via Tech-talk
Re: SNCSEQ Error Windows Mark Rivers via Tech-talk
RE: SNCSEQ Error Windows Hetz, Benjamin via Tech-talk
Re: SNCSEQ Error Windows Benjamin Franksen via Tech-talk
RE: SNCSEQ Error Windows Freddie Akeroyd - UKRI STFC via Tech-talk
Prev: ADMythen Mark Rivers via Tech-talk
Next: Re: Standard RTEMS NFSv3 client Matt Rippa via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: RE: SNCSEQ Error Windows Freddie Akeroyd - UKRI STFC via Tech-talk
Next: Building EPICS base/IOC only for cross target Florian Feldbauer via Tech-talk
