Am 26.03.20 um 09:49 schrieb Kivel Niko (PSI):
> In the doc, this example is given:
> {calc: {expr:"A*B", args:[{db:"record.VAL"}, 1.5], prec:3}}
> which uses the link type 'calc', which must be a valid link type
> according to the documentation. However, I receive the same error.
This is consistent. we already established that {db:"record.VAL"} is not
a valid JSON link so according to the docs, the whole "calc" is neither.
> Whenever I use anything author than 'pva'.
> Also, if (and it doesn't sound that strange)
> "{db:"${SYS}:constFloatPi"}" is as valid PV, so is
> "{pva:"${SYS}:constFloatPi"}", which works perfectly fine.
I guess it's called "extensible link types" for a reason ;-)
So in base-7.0 there has to be a module that extends the JSON link
syntax to handle "pva" links. But there is no extension that handles
"db". You may of course question why this is so and I can't answer that,
except that it seems to be a feature that is currently not supported.
Cheers
Ben
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (Sprecher), Prof. Dr. Jan Lüning, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
pEpkey.asc
Description: application/pgp-keys
- PV Access Rolf Keitel via Tech-talk
- Re: PV Access Johnson, Andrew N. via Tech-talk
- Re: PV Access Kivel Niko (PSI) via Tech-talk
- Re: PV Access Ralph Lange via Tech-talk
- Re: PV Access Ben Franksen via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
