1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: PV Access
From: Ben Franksen via Tech-talk <[email protected]>
To: Ralph Lange <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Thu, 26 Mar 2020 10:42:24 +0100
Am 26.03.20 um 10:18 schrieb Ralph Lange via Tech-talk:
> The '{db:"record.VAL"}' definition appears in the *configuration* of the
> calc-Link.
> Every new link type (listed at the head of the referenced document) defines
> its own syntax for JSON configuration. The namespace for the keys in that
> configuration syntax is completely separate. The fact that the calc link
> understands a "db:" tag in its configuration does not mean that
> tag/functionality is available anywhere else, e.g. in the configuration of
> a different link type or at top level when configuring a field in a
> database record.
The documentation does not mention "db" as a valid JSON link type at
all. This keyword only appears in the example. At the same time, the
docs say:
args
A JSON list of up to 12 input arguments for the expression, which are
assigned to the inputs A, B, C, ... L. Each input argument may be either
a numeric literal or an embedded JSON link inside {} braces. [...]
I guess the docs couldbe a bit clearer here. At least providing a
reference to where this "db" JSON link type is defined.
> All existing link types (DB/CA, numerical CONSTANT, hardware links from
> link.h) continue to work as before - otherwise introduction of the link
> support would have broken all existing applications and databases. (We're
> not *that* evil.)
A clean break would have been a possibility that I would hesitate to
call "evil", /if/ publicly anncounced and with a deprecation period. If
it had been deprecated in base-3.15, then I guess removing support for
such PV names in base-7.0 would be perfectly appropriate. The number of
affected users probably tends to zero anyway.
Just my 2 cents.
Cheers
Ben
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (Sprecher), Prof. Dr. Jan Lüning, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Attachment: pEpkey.asc
Description: application/pgp-keys
Re: PV Access Kivel Niko (PSI) via Tech-talk
PV Access Rolf Keitel via Tech-talk
Re: PV Access Johnson, Andrew N. via Tech-talk
Re: PV Access Ralph Lange via Tech-talk
Re: PV Access Ben Franksen via Tech-talk
Prev: Re: PV Access Marty Kraimer via Tech-talk
Next: Re: PV Access Kivel Niko (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: PV Access Ralph Lange via Tech-talk
