1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Filtering messages print on the IOC shell console
To: "J. Lewis Muir" <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Thu, 9 Apr 2020 18:18:13 +0000
I was going to test the hypothesis that the problem was that stderr needed an fflush after each command.  I was hoping that this would be easy to do from the vxWorks shell, but I'm not sure how to get the FILE  pointer to stderr from the command line?
I want to see if the garbling goes away if I do this in the startup script:
dbLoadTemplate(...)
fflush(stderr)
Sent: Thursday, April 9, 2020 1:00 PM
To: EPICS Tech-Talk
Cc: 'Konrad, Martin'; Johnson, Andrew N.; Mark Rivers
On 03/27, Mark Rivers wrote:
> Hi Martin,
> > dbLoadTemplate.y is printing messages using fprintf(stderr,...);
> > My recommendation would be to print all messages to the same stream.
> Unfortunately this is out of my control.  The problem I am seeing is the garbling of output from dbLoadTemplate (EPICS base) and the echoing of subsequent vxWorks shell commands (Wind River).
> But this suggests that the vxWorks shell is proceeding to execute the next command before the previous one has displayed all of its output on the console?  This does not seem correct.
Any more thoughts on this garbled output issue?  Specifically, how can
it be fixed?
Thanks!
Lewis
Re: Filtering messages print on the IOC shell console Johnson, Andrew N. via Tech-talk
Filtering messages print on the IOC shell console Paduan Donadio, Marcio via Tech-talk
Re: Filtering messages print on the IOC shell console Konrad, Martin via Tech-talk
RE: Filtering messages print on the IOC shell console Mark Rivers via Tech-talk
Re: Filtering messages print on the IOC shell console J. Lewis Muir via Tech-talk
Prev: Re: Filtering messages print on the IOC shell console J. Lewis Muir via Tech-talk
Next: RE: StreamDevice, prevent records from getting "stuck" Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: Filtering messages print on the IOC shell console Johnson, Andrew N. via Tech-talk
