1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: SoftIOC and Labview
From: Paul Sichta via Tech-talk <[email protected]>
To: "Mostafa, Jalal (IPE)" <[email protected]>
Date: Wed, 27 May 2020 10:47:07 -0400
Jalal,
I looked in my 3.14.12.5  IOC's database and I write DOUBLE from LabVIEW using the NI-supplied software.  Here is my record;
grecord(waveform,"tc_nbBoard1_WF") {
        field(DESC,"Temperatures array")
        field(ASG,"OPEN")
        field(PINI,"YES")
        field(DTYP,"Soft Channel")
        field(NELM,"80")
        field(FTVL,"DOUBLE")
This worked with labview 2014 and 2016.  Haven't tried newer versions.
-ps
On Tue, May 26, 2020 at 4:55 PM Paul Sichta <[email protected]> wrote:
Jalal,
I was able to r/w using U32 data to a waveform record.
I'd have to dig a little to resurrect the details, perhaps later.
-ps
On Tue, May 26, 2020 at 3:36 PM Mostafa, Jalal (IPE) <[email protected]> wrote:
Writing double scalar values to a ai record works great.
I tried both aai and waveform to write array values of doubles but no success.
I am using LabView 2018 SP1. Do you have a list of what's working and what's not?
Best,
Jalal
Sent: Tuesday, May 26, 2020 9:28:39 PM
To: Mostafa, Jalal (IPE)
Cc: [email protected]
Jalal,
Can your labview write scalar values (e.g. to a longin record ) to your softioc?
Have you tried writing your labview array to a waveform record on the softioc?
Using earlier versions of the NI EPICS software, I seem to recall there were some data types that wouldn't work (I think double was OK).  I haven't tried the 2020 version but glad to see it has been updated.
-ps
On Tue, May 26, 2020 at 3:18 PM Mostafa, Jalal (IPE) via Tech-talk <[email protected]> wrote:
Hi All!
I am trying to write an array of doubles from a LabView EPICS Client using EPICS Client I/O Server to a softIoc instance with the corresponding record:
record(aai, "dummy:array")
    field(NELM, "10")
    field(FTVL, "DOUBLE")
I can see the LabVIEW being connected to this record but no written values to softIoc instance. The issue is only happening on LabView but not when using other clients like caput for instance.
What is the correct way to write array values from LabView to softIoc records?
Best,
Jalal
Re: SoftIOC and Labview Mostafa, Jalal (IPE) via Tech-talk
Re: SoftIOC and Labview Paul Sichta via Tech-talk
Prev: RE: Strange problem with areaDetector driver Mark Rivers via Tech-talk
Next: Re: Unpredictable behaviour with PyEpics Matt Newville via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: RE: SoftIOC and Labview Kathryn Baker - UKRI STFC via Tech-talk
Next: Re: SoftIOC and Labview Mostafa, Jalal (IPE) via Tech-talk
