Subject: Re: How to run IOC in docker containers properly
From: Ben Franksen via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Fri, 19 Jun 2020 15:28:52 +0200
Am 18.06.20 um 18:18 schrieb Ralph Lange via Tech-talk:
> On Thu, 18 Jun 2020 at 17:37, Michael Davidsaver <[email protected]>
> wrote:
>> Why not bake procServ into the IOC executable?  It could still fork() off
>> the a child process for the actual IOC, but without an execvp().
>> (or at worst, to re-exec the same executable)
>> Of course fork() from a multi-threaded process needs some care.
>> As well as attention to FD_CLOEXEC.
> As you know, the traditional Linux approach is to break up applications
> with large complex functionality into small independent units that each
> serve a narrow scope of purpose and can be combined on the command line.
> procServ is following that approach.
> Looking at the list of command line options and features of procServ (that
> were all added on user request btw.) - do you want all this being part of
> the IOC?
> Your idea sounds a lot like the CA Gateway's quirky server mode - that IMHO
> should be deprecated in favor of running it under procServ, to put an end
> to running two hardly distinguishable processes for each Gateway instance.
Exactly right, on all points.
Cheers
Ben
Attachment: signature.asc
Description: OpenPGP digital signature
How to run IOC in docker containers properly xiao zhang via Tech-talk
Re: How to run IOC in docker containers properly Johnson, Andrew N. via Tech-talk
Re: How to run IOC in docker containers properly Ben Franksen via Tech-talk
Re: How to run IOC in docker containers properly J. Lewis Muir via Tech-talk
Re: How to run IOC in docker containers properly Konrad, Martin via Tech-talk
Re: How to run IOC in docker containers properly Michael Davidsaver via Tech-talk
Re: How to run IOC in docker containers properly Ralph Lange via Tech-talk
Prev: Re: How to run IOC in docker containers properly Ben Franksen via Tech-talk
Next: Re: How to run IOC in docker containers properly Ben Franksen via Tech-talk
Prev: Re: How to run IOC in docker containers properly Michael Davidsaver via Tech-talk
Next: Re: How to run IOC in docker containers properly Mark Rivers via Tech-talk
