Subject: Re: How to run IOC in docker containers properly
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Fri, 19 Jun 2020 16:30:46 +0200
On Fri, 19 Jun 2020 at 15:35, Ben Franksen via Tech-talk <[email protected]> wrote:
I must say that being able to scroll back the history is /really/ nice
from a UI perspective. I didn't know screen has this ability. Does that
work in conjunction with accessing the IOC consoles via conserver?
Conserver can be set up to do this, with a limited buffer size.
@Andrew:
Conserver also does time stamped logging, authentication, authorization (read/only access to consoles, access only to a subset) and adds a layer of naming and redirection between servers, so that - if configured correctly, which is not simple - typing
    console <iocname>
on any workstation will connect you to the console of that IOC, no matter where it lives and how it is connected (procServ, terminal server, serial line,...), with exactly the access rights that you should have.
Cheers,
~Ralph
Re: How to run IOC in docker containers properly Ben Franksen via Tech-talk
How to run IOC in docker containers properly xiao zhang via Tech-talk
Re: How to run IOC in docker containers properly Johnson, Andrew N. via Tech-talk
Re: How to run IOC in docker containers properly J. Lewis Muir via Tech-talk
Re: How to run IOC in docker containers properly Konrad, Martin via Tech-talk
Re: How to run IOC in docker containers properly Mark Rivers via Tech-talk
Prev: Re: How to run IOC in docker containers properly Ben Franksen via Tech-talk
Next: Device support for Lakeshore 211 for temperature monitor Balakrishnan, Namrata via Tech-talk
Next: Re: How to run IOC in docker containers properly Ben Franksen via Tech-talk
