1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Process at Init of mbbo-record
To: Mark Rivers <[email protected]>, "'Nonn, Patrick'" <[email protected]>
Date: Thu, 9 Jul 2020 04:17:04 +0000
The record "Tst/4Config/targetStream" in question has these two fields different from other records:
ORAW: 0    RVAL: 0
Otherwise, all other fields are the same or look reasonably similar.
Since you are using autosave, why do you use set_pass1 instead of set_pass0? Is the record "Tst/4Config/targetStream" being auto-restored? If so, check the .sav file for its VAL, RVAL.
Yong
On 7/8/20, 3:17 PM, "Tech-talk on behalf of Mark Rivers via Tech-talk" <[email protected] on behalf of [email protected]> wrote:
    I'm not sure why RVAL is 0 for record 4, but 3 for records 3 and 5.
    But the first place to look is your device support.  You are using some custom device support for these records, and that could be setting RVAL incorrectly.  You can add some debugging in the functions in device support to print the value of RVAL.
    The asyn device support for mbbo, for example, reads the current value from the hardware into the RVAL field.  If your device support does something like that then that could explain RVAL not being 3 as you expect.
    -----Original Message-----
    Sent: Wednesday, July 8, 2020 9:27 AM
    here the dbpr outputs with high detail level:
    epics> dbpr Tst/4Config/targetStream 5
    ACKS: NO_ALARM      ACKT: YES           ASG :               ASP : PTR (nil)
    BKLNK: ELL 0 [(nil) .. (nil)]           BKPT: 00            COSV: NO_ALARM
    DESC:               DISA: 0             DISP: 0             DISS: NO_ALARM
    DISV: 1             DOL : CONSTANT      DPVT: PTR 0x5626b806af70
    DSET: PTR 0x7f19cac50a40                DTYP: ChimeraTK     EIST:
    EISV: NO_ALARM      EIVL: 0x0           ELST:               ELSV: NO_ALARM
    ELVL: 0x0           EVNT:               FFST:               FFSV: NO_ALARM
    FFVL: 0x0           FLNK: CONSTANT      FRST:               FRSV: NO_ALARM
    FRVL: 0x0           FTST:               FTSV: NO_ALARM      FTVL: 0x0
    FVST:               FVSV: NO_ALARM      FVVL: 0x0
    IVOA: Continue normally                 IVOV: 0             LALM: 3
    LCNT: 0             LSET: PTR 0x5626b801ec80                MASK: 0
    MLIS: ELL 1 [0x7f1964041eb8 .. 0x7f1964041eb8]
    MLOK: b0 a6 03 b8 26 56 00 00           MLST: 3
    NAME: Tst/4Config/targetStream          NIST:               NISV: NO_ALARM
    NIVL: 0x0           NOBT: 0             NSEV: NO_ALARM      NSTA: NO_ALARM
    OMSL: supervisory   ONST: Logfile Only  ONSV: NO_ALARM      ONVL: 0x1
    ORAW: 0             ORBV: 0
    OUT : INST_IO @ChimeraTKApp processes/4/config/targetStream PACT: 0
    PHAS: 0             PINI: YES           PPN : PTR (nil)     PPNR: PTR (nil)
    PRIO: LOW           PROC: 0             PUTF: 0             RBV : 0
    RDES: PTR 0x5626b7b956c0                RPRO: 0
    RSET: PTR 0x7f19cac4b740                RVAL: 0             SCAN: Passive
    SDEF: 1             SDIS: CONSTANT      SEVR: NO_ALARM      SHFT: 0
    SIML: CONSTANT      SIMM: NO            SIMS: NO_ALARM      SIOL: CONSTANT
    SPVT: PTR (nil)     STAT: NO_ALARM      SVST:               SVSV: NO_ALARM
    SVVL: 0x0           SXST:               SXSV: NO_ALARM      SXVL: 0x0
    TEST:               TESV: NO_ALARM      TEVL: 0x0           THST: No Logging
    THSV: NO_ALARM      THVL: 0x3           TIME: 2020-07-08 15:21:27.256869741
    TPRO: 0             TSE : 0             TSEL: CONSTANT      TTST:
    TTSV: NO_ALARM      TTVL: 0x0           TVST:               TVSV: NO_ALARM
    TVVL: 0x0           TWST: StdOut Only   TWSV: NO_ALARM      TWVL: 0x2
    UDF : 0             UDFS: INVALID       UNSV: NO_ALARM      VAL : 3
    ZRST: Logfile + StdOut                  ZRSV: NO_ALARM      ZRVL: 0x0
    epics> dbpr Tst/3Config/targetStream 5
    DISV: 1             DOL : CONSTANT      DPVT: PTR 0x5626b80871a0
    LCNT: 0             LSET: PTR 0x5626b801e9c0                MASK: 0
    MLIS: ELL 1 [0x7f1964042490 .. 0x7f1964042490]
    MLOK: d0 a5 03 b8 26 56 00 00           MLST: 3
    NAME: Tst/3Config/targetStream          NIST:               NISV: NO_ALARM
    ORAW: 3             ORBV: 0
    OUT : INST_IO @ChimeraTKApp processes/3/config/targetStream PACT: 0
    RSET: PTR 0x7f19cac4b740                RVAL: 3             SCAN: Passive
    THSV: NO_ALARM      THVL: 0x3           TIME: 2020-07-08 15:21:27.256855004
    epics> dbpr Tst/5Config/targetStream 5
    DISV: 1             DOL : CONSTANT      DPVT: PTR 0x5626b8088680
    LCNT: 0             LSET: PTR 0x5626b801ef40                MASK: 0
    MLIS: ELL 1 [0x7f19640418e0 .. 0x7f19640418e0]
    MLOK: 90 a7 03 b8 26 56 00 00           MLST: 3
    NAME: Tst/5Config/targetStream          NIST:               NISV: NO_ALARM
    ORAW: 3             ORBV: 0
    OUT : INST_IO @ChimeraTKApp processes/5/config/targetStream PACT: 0
    THSV: NO_ALARM      THVL: 0x3           TIME: 2020-07-08 15:21:27.256896931
    I did check the errors and warnings, and did find nothing. But four eyes see more...
    Adding 8 processes.
    Adding filesystem monitor for: sda3 mounted at: / -->0
    Adding filesystem monitor for: sda4 mounted at: /home -->1
    Adding network monitor for device: enp2s0f1 -->0
    Adding network monitor for device: wlp3s0 -->1
    #!/home/countzero/ChimeraTK/install/bin/watchdog-server
    #< envPaths
    dbLoadDatabase("../dbd/ChimeraTK.dbd",0,0)
    ChimeraTK_registerRecordDeviceDriver(pdbbase)
    chimeraTKConfigureApplication("ChimeraTKApp", 100)
    ## Setup autosave
    set_requestfile_path("../db/")
    set_savefile_path("../autosave/")
    ## Load record instances
    dbLoadRecords("../db/WatchdogServer-main.db", "SERVER=Tst")
    dbLoadRecords("../db/WatchdogServer-proc.db", "SERVER=Tst, P=0")
    dbLoadRecords("../db/WatchdogServer-proc.db", "SERVER=Tst, P=1")
    dbLoadRecords("../db/WatchdogServer-proc.db", "SERVER=Tst, P=2")
    dbLoadRecords("../db/WatchdogServer-proc.db", "SERVER=Tst, P=3")
    dbLoadRecords("../db/WatchdogServer-proc.db", "SERVER=Tst, P=4")
    dbLoadRecords("../db/WatchdogServer-proc.db", "SERVER=Tst, P=5")
    dbLoadRecords("../db/WatchdogServer-proc.db", "SERVER=Tst, P=6")
    dbLoadRecords("../db/WatchdogServer-proc.db", "SERVER=Tst, P=7")
    save_restoreSet_DatedBackupFiles(0)
    save_restoreSet_Debug(0)
    save_restoreSet_NumSeqFiles(3)
    save_restoreSet_SeqPeriodInSeconds(3600)
    #set_pass0_restoreFile("WatchdogServer-main.sav", "SERVER=Tst")
    set_pass1_restoreFile("WatchdogServer-main.sav", "SERVER=Tst")
    #set_pass0_restoreFile("Processes.sav", "SERVER=Tst")
    set_pass1_restoreFile("Processes.sav", "SERVER=Tst")
    iocInit()
    Starting iocInit
    ## EPICS R3.16.2
    ## EPICS Base built Jun 11 2020
    reboot_restore: entry for file 'WatchdogServer-main.sav'
    reboot_restore: Found filename 'WatchdogServer-main.sav' in restoreFileList.
    *** restoring from '../autosave/WatchdogServer-main.sav' at initHookState 7 (after record/device init) ***
    reboot_restore: done with file 'WatchdogServer-main.sav'
    reboot_restore: entry for file 'Processes.sav'
    reboot_restore: Found filename 'Processes.sav' in restoreFileList.
    *** restoring from '../autosave/Processes.sav' at initHookState 7 (after record/device init) ***
    reboot_restore: done with file 'Processes.sav'
    #postEvent 1
    create_monitor_set("WatchdogServer-main.req", 60, "SERVER=Tst")
    create_monitor_set("Processes.req", 60, "SERVER=Tst")
    Processes.sav: 136 of 136 PV's connected
    WatchdogServer-main.sav: 25 of 25 PV's connected
    epics>
    Patrick
    ----- Original Message -----
    To: "Patrick Nonn" <[email protected]>
    Cc: "tech-talk" <[email protected]>
    Sent: Wednesday, 8 July, 2020 15:53:15
    Subject: RE: Process at Init of mbbo-record
    Hi Patrick,
    I forgot to CC tech-talk on my original reply.
    Your st.cmd got stripped out by the mail system, please rename to st.cmd.txt before attaching.
    Please use the details=5 flag on the dbpr commands, e.g.
    Did you check carefully for any warnings or errors in the iocsh output when starting the IOC?
    Sent: Wednesday, July 8, 2020 8:25 AM
    the db-file and the start-script, where it is loaded, is attached. I have also attached the req files used to set the record via save_restore, just in case. The dbpr output is:
    ASG :               DESC:               DISA: 0             DISP: 0
    DISV: 1             NAME: Tst/4Config/targetStream          RBV : 0
    RVAL: 0             SEVR: NO_ALARM      STAT: NO_ALARM      TPRO: 0
    VAL : 3
    I have also looked at the mbbo record loaded afterwards:
    epics> dbpr Tst/4Config/logLevel
    DISV: 1             NAME: Tst/4Config/logLevel              RBV : 0
    RVAL: 3             SEVR: NO_ALARM      STAT: NO_ALARM      TPRO: 0
    VAL : 3
    and as you can see, it is processed correctly at init, as is the targetStream record before:
    DISV: 1             NAME: Tst/3Config/targetStream          RBV : 0
    VAL : 3
    and afterwards:
    DISV: 1             NAME: Tst/5Config/targetStream          RBV : 0
    VAL : 3
    Patrick
    Sent: Wednesday, 8 July, 2020 15:07:42
    Can you show:
    - The database file
    - The commands to load it 8 times
    - The output of the following command at the iocsh, where (record) is the name of the 5'th record loaded.
    dbpr (record) 5
    From: Tech-talk <[email protected]> on behalf of Nonn, Patrick via Tech-talk <[email protected]>
    Sent: Wednesday, July 8, 2020 7:47 AM
    To: tech-talk
    Subject: Process at Init of mbbo-record
    I observe some odd behaviour. I have changed a longout record to an mbbo record, either with passive scan and pini=1. This record is loaded eight times with different macros. After the change to mbbo, the 5th instance of this record is not processed during init (VAL is set, RVAL is 0). This is true, even if the sequence, in which the different instances are loaded, are switched. Could this be a timing issue of some sort?
    Greetings
    Patrick
Re: Process at Init of mbbo-record Nonn, Patrick via Tech-talk
RE: Process at Init of mbbo-record Mark Rivers via Tech-talk
Prev: Re: Asyn/StreamDevice for HP3458A through Agilent E5810 LAN/GPIB Gateway Hu, Yong via Tech-talk
Next: Re: Process at Init of mbbo-record Nonn, Patrick via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: RE: Process at Init of mbbo-record Mark Rivers via Tech-talk
