1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: EPICS7 and Python
From: Matt Newville via Tech-talk <[email protected]>
To: Juan F. Esteban Müller <[email protected]>
Cc: "Cobb, Tom \(DLSLtd,RAL,LSCI\) via Tech-talk" <[email protected]>
Date: Tue, 18 Aug 2020 11:48:08 -0500
Hi Juan
On Tue, Aug 18, 2020 at 11:27 AM Juan F. Esteban Müller <[email protected]> wrote:
Thanks for your replies, Tom, Michael, and Matt.
It looks like indeed the problem is that pyepics is using a different version of the EPICS libraries. I might have been confused about how this is done.
I installed pyepics and p4p using pip, and it was fetching epicscorelibs, but then I was setting PYEPICS_LIBCA to use a patched 7.0.4 to fix a couple of other issues I was having (https://github.com/epics-base/pva2pva/pull/34, https://github.com/epics-base/epics-base/issues/83).
It seems that pyepics is using that environment variable, but p4p is ignoring it, so each module is trying to load different versions of the libraries. I was probably lucky that it worked in the past with Python 3.7.3 on macos Mojave and on Python 2.7.
I believe they would need to load the same version of libca (that is, if p4p loads libca - I'm not sure it does).   But it does work to use the pyepics-default libca / libCom, which are definitely not going to be seen or used by p4p.  So, that seems a little strange.    Maybe there is something different with 7.0.4?
Anyway, that's why pyepics has the PYEPICS_LIBCA environmental variable and does not load the library at import time, but waits as late as possible to load the library.
--Matt
EPICS7 and Python Juan F. Esteban Müller via Tech-talk
Re: EPICS7 and Python Matt Newville via Tech-talk
Re: EPICS7 and Python Juan F. Esteban Müller via Tech-talk
Prev: Re: EPICS7 and Python Juan F. Esteban Müller via Tech-talk
Next: Re: redundancy materials Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: redundancy materials saleem khan via Tech-talk
