1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: running gateway on mac
From: "Smith, Martin via Tech-talk" <[email protected]>
To: Vivian O'Dell <[email protected]>
Date: Tue, 1 Sep 2020 15:24:32 +0000
I might be way off on the solution here but seems to me that your pvlist file
does not match your access rules.
You should have something in your pvlist file like this I think
Tracker:.*       ALLOW DEFAULT 1
This will match your access file rule for ASG DEFAULT otherwise you should have
a rule for the "Tracker" ASG as well as the DEFAULT.
Marty
Sent: Tuesday, September 1, 2020 9:58 AM
To: Smith, Martin <[email protected]>
Cc: [email protected] <[email protected]>; Vivian O'Dell <[email protected]>
Hi Marty,
I have the following files (that I modified from the examples)
TRACKER.pvlist
EVALUATION ORDER ALLOW, DENY
[0-9].*          ALLOW
[a-z].*          ALLOW
[A-Z].*          ALLOW
Tracker:.*       ALLOW Tracker 1
gateway:.*Flag   ALLOW GatewayAdmin
# Convert old Gateway internal process variable names
gateway\.\(.*\)            ALIAS     gateway:\1
gateway\.\(.*\)Flag        ALIAS     gateway:\1Flag          GatewayAdmin
gateway\.alive             ALIAS     gateway:connected
gateway\.postEventRate     ALIAS     gateway:clientPostRate
TRACKER.access
mac-130048:example odell$ cat TRACKER.access
ASG(DEFAULT) {
   RULE(1,READ)
   RULE(1,WRITE)
And I’m now running gateway by:
../bin/darwin-x86/gateway -sport 5069 -pvlist TRACKER.pvlist -access TRACKER.access -server
I still get:
mac-130048:example odell$ caget Tracker:LV1:Status
Channel connect timed out: 'Tracker:LV1:Status' not found.
thanks!
Vivian
On Sep 1, 2020, at 9:22 AM, Smith, Martin <[email protected]> wrote:
Hi Vivian,
Do you have your access security files set up like the pvlist and access files?
If you don't set these up then you won't even get read access to PVs.
Hope this helps
Marty
From: Tech-talk <[email protected]> on behalf of Vivian O'Dell via Tech-talk <[email protected]>
Sent: Tuesday, September 1, 2020 9:07 AM
To: [email protected] <[email protected]>
Subject: running gateway on mac
I’m trying to run gateway on my mac. I have PVs defined in EPICs, and
if I use caget locally, it works fine, but when I try to use gateway I get the
following message:
mac-130048:darwin-x86 odell$ caget Tracker:LV1:Status
CAC: Unable to connect because "Connection refused"
CAC TCP socket linger set error was Invalid argument
CAC TCP socket shutdown error was Socket is not connected
I am using the following command to start the gateway:
 ./gateway -sport 5069 -server
I also have the following environment variables set:
EPICS_BASE=/Users/odell//base-3.15.7
EPICS_CA_AUTO_ADDR_LIST=NO
EPICS_HOST_ARCH=darwin-x86
EPICS_CA_ADDR_LIST=
EPICS_CA_NAME_SERVERS=localhost:5069
The result I get is:
I am using gateway 2.1.2. I get the same result with older versions
of gateway.
Any ideas of where to look for the problem?
thanks,
Vivian
Re: running gateway on mac Vivian O'Dell via Tech-talk
AreaDetector: PVs from driver created parameters not updating David Vine via Tech-talk
Re: AreaDetector: PVs from driver created parameters not updating Mark Rivers via Tech-talk
Re: running gateway on mac Smith, Martin via Tech-talk
Prev: Re: running gateway on mac Vivian O'Dell via Tech-talk
Next: Re: running gateway on mac Vivian O'Dell via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
