Thanks, Marty — tried that, still no joy… sigh. — Viv
I might be way off on the solution here but seems to me that your pvlist file
does not match your access rules.
You should have something in your pvlist file like this I think
Tracker:.* ALLOW DEFAULT 1
This will match your access file rule for ASG DEFAULT otherwise you should have
a rule for the "Tracker" ASG as well as the DEFAULT.
Marty
Hi Marty,
I have the following files (that I modified from the examples)
TRACKER.pvlist
EVALUATION ORDER ALLOW, DENY
[0-9].* ALLOW
[a-z].* ALLOW
[A-Z].* ALLOW
Tracker:.* ALLOW Tracker 1
gateway:.*Flag ALLOW GatewayAdmin
# Convert old Gateway internal process variable names
gateway\.\(.*\) ALIAS gateway:\1
gateway\.\(.*\)Flag ALIAS gateway:\1Flag GatewayAdmin
gateway\.alive ALIAS gateway:connected
gateway\.postEventRate ALIAS gateway:clientPostRate
TRACKER.access
mac-130048:example odell$ cat TRACKER.access
ASG(DEFAULT) {
RULE(1,READ)
RULE(1,WRITE)
And I’m now running gateway by:
../bin/darwin-x86/gateway -sport 5069 -pvlist TRACKER.pvlist -access TRACKER.access -server
I still get:
mac-130048:example odell$ caget Tracker:LV1:Status
Channel connect timed out: 'Tracker:LV1:Status' not found.
thanks!
Vivian
Hi Vivian,
Do you have your access security files set up like the pvlist and access files?
If you don't set these up then you won't even get read access to PVs.
Hope this helps
Marty
I’m trying to run gateway on my mac. I have PVs defined in EPICs, and
if I use caget locally, it works fine, but when I try to use gateway I get the
following message:
mac-130048:darwin-x86 odell$ caget Tracker:LV1:Status
CAC: Unable to connect because "Connection refused"
CAC TCP socket linger set error was Invalid argument
CAC TCP socket shutdown error was Socket is not connected
I am using the following command to start the gateway:
./gateway -sport 5069 -server
I also have the following environment variables set:
EPICS_BASE=/Users/odell//base-3.15.7
EPICS_CA_AUTO_ADDR_LIST=NO
EPICS_HOST_ARCH=darwin-x86
EPICS_CA_ADDR_LIST=
EPICS_CA_NAME_SERVERS=localhost:5069
The result I get is:
I am using gateway 2.1.2. I get the same result with older versions
of gateway.
Any ideas of where to look for the problem?
thanks,
Vivian
- Re: running gateway on mac Pierrick M Hanlet via Tech-talk
- AreaDetector: PVs from driver created parameters not updating David Vine via Tech-talk
- Re: AreaDetector: PVs from driver created parameters not updating Mark Rivers via Tech-talk
- running gateway on mac Vivian O'Dell via Tech-talk
- Re: running gateway on mac Smith, Martin via Tech-talk
- Re: running gateway on mac Vivian O'Dell via Tech-talk
Re: PTP hardware timestamps in EPICS facilities Pilar Gil via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
