Subject: AW: autosave 5-10-1 on RTEMS-4.10.2, mount failed
From: "Sintschuk, Michael via Tech-talk" <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 23 Sep 2020 07:48:05 +0000
That works.
Thanks for the support!
Michael
Von: Johnson, Andrew N. <[email protected]>
Gesendet: Dienstag, 22. September 2020 17:59
An: Sintschuk, Michael <[email protected]>
Betreff: Re: autosave 5-10-1 on RTEMS-4.10.2, mount failed
On Sep 22, 2020, at 8:02 AM, Sintschuk, Michael via Tech-talk <[email protected]> wrote:
When the IOC is writing the sav-Files it looks like this:
/autosave/iocRtems # ll
total 196
-rw-rw-rw- 1 bl     users   6952 Sep 16 11:21 auto_positions.req
-rw-rw-r-- 1 nobody nobody  3862 Sep 22 14:43 auto_positions.sav
-rw-rw-r-- 1 nobody nobody  3862 Sep 22 14:43 auto_positions.savB
-rw-rw-rw- 1 nobody nobody  3862 Sep 22 14:42 auto_positions.sav_200922-124257
-rw-rw-rw- 1 bl     users   6864 Sep 16 11:24 auto_settings.req
-rw-rw-r-- 1 nobody nobody 56574 Sep 22 14:43 auto_settings.sav
-rw-rw-r-- 1 nobody nobody 56574 Sep 22 14:43 auto_settings.savB
-rw-rw-rw- 1 nobody nobody 56574 Sep 22 14:42 auto_settings.sav_200922-124258
They belong to nobody… Probably I’m still missing some proper DHCP/DNS configuration?
No, the user and group that you want the IOC to use should be given in the nfsMount command. Instead of
nfsMount("192.168.99.1","/autosave","/autosave")
you should use
nfsMount("[email protected]","/autosave","/autosave")
where uid and gid are replaced by the numeric IDs that you want RTEMS to use for your files. Running the command ‘id bl’ on your workstation should give you those numbers (assuming bl is the account you want it to use).
But anyway, the IOC is now saving/loading the correct settings.
Glad to hear you’re making progress.
- Andrew
Complexity comes for free, simplicity you have to work for.
autosave 5-10-1 on RTEMS-4.10.2, mount failed Sintschuk, Michael via Tech-talk
Re: autosave 5-10-1 on RTEMS-4.10.2, mount failed Hu, Yong via Tech-talk
AW: autosave 5-10-1 on RTEMS-4.10.2, mount failed Sintschuk, Michael via Tech-talk
Re: autosave 5-10-1 on RTEMS-4.10.2, mount failed Johnson, Andrew N. via Tech-talk
Prev: Re: RE: How to build MEDM (Jetson nano) Hinko Kocevar via Tech-talk
Next: Job Openings at Fermilab James F Patrick via Tech-talk
Prev: Re: autosave 5-10-1 on RTEMS-4.10.2, mount failed Johnson, Andrew N. via Tech-talk
Next: Does edm static widget support chinese input? Silver via Tech-talk
