That fixed it. I should have noticed that the Makefile has a commented out line to do that. This is the "git diff" that fixes the problem.
-USR_LIBS_Linux = Xm Xt Xp Xmu X11 Xext
+#USR_LIBS_Linux = Xm Xt Xp Xmu X11 Xext
#Xp is not available and not needed on Linux Mint 18
-#USR_LIBS_Linux = Xm Xt Xmu X11 Xext
+USR_LIBS_Linux = Xm Xt Xmu X11 Xext
-----Original Message-----
Sent: Thursday, October 22, 2020 3:34 PM
To: Johnson, Andrew N. <[email protected]>
Cc: Mark Rivers <[email protected]>; EPICS tech-talk <[email protected]>
Subject: Re: MEDM crash
Mark,
Try to compile without Xp. makefile should contains
instead of
Han
On Thu, Oct 22, 2020 at 1:30 PM Johnson, Andrew N. via Tech-talk <[email protected]> wrote:
> IIRC there are some libraries that are no longer needed and that might be one of them, try modifying the Makefile to take that out and see whether it builds.
> - Andrew
> On Oct 22, 2020, at 3:22 PM, Mark Rivers <[email protected]> wrote:
> Ø As Bob pointed out you have an empty include path in your build. The last -I option there was eating up the -MM which explains the error message, so one of your extensions config variables was probably empty.
> I solved that. I was missing this file that needs to define X11_LIB and MOTIF_LIB:
> extensions/configure/os/CONFIG_SITE.linux-x86_64-ub18.linux-x86_64-ub1
> 8
> However, now I get this error:
> -lANLwidgets -lPrintUtils -lca -lCom -lXm -lXt -lXp -lXmu -lX11 -lXext -lpthread -lreadline -lm -lrt -ldl -lgcc
> /usr/bin/ld: cannot find -lXp
> collect2: error: ld returned 1 exit status
> /corvette/usr/local/epics/base/configure/RULES_BUILD:212: recipe for
> target 'medm' failed
> I have Googled to see what package provides libXp.so on Ubuntu 18, and I can’t find it. Others have the same problem.
> Pete and Bob how did you install libXp.so?
> Mark
> From: Johnson, Andrew N. <[email protected]>
> Sent: Thursday, October 22, 2020 3:14 PM
> To: Mark Rivers <[email protected]>
> Cc: Soliday, Robert T. <[email protected]>; EPICS tech-talk
> <[email protected]>
> On Oct 22, 2020, at 1:54 PM, Mark Rivers <[email protected]> wrote:
> That PR builds OK on Centos 7, but it fails to build on Ubuntu 18. I see the same failure on Ubuntu 18 with the MEDM_3_1_14 tag.
> TahoeU18:/corvette/usr/local/epics/extensions_new/src/medm_fix> make
> make -C ./printUtils install
> make[1]: Entering directory '/corvette/usr/local/epics/extensions_new/src/medm_fix/printUtils'
> make -C O.linux-x86_64-ub18 -f ../Makefile TOP=../../../.. \
> T_A=linux-x86_64-ub18 install
> make[2]: Entering directory '/corvette/usr/local/epics/extensions_new/src/medm_fix/printUtils/O.linux-x86_64-ub18'
> /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I/corvette/usr/local/epics/base/include/compiler/gcc -I/corvette/usr/local/epics/base/include/os/Linux -I/corvette/usr/local/epics/base/include -I../../../../include -I -MM -MF xwd2ps.d ../xwd2ps.c
> cc1: error: to generate dependencies you must specify either -M or -MM
> - Andrew
> Complexity comes for free, simplicity you have to work for.
- Re: MEDM crash Torsten Bögershausen via Tech-talk
- MEDM crash Siddons, David via Tech-talk
- RE: MEDM crash Soliday, Robert T. via Tech-talk
- Re: MEDM crash Johnson, Andrew N. via Tech-talk
- Re: MEDM crash Mark Rivers via Tech-talk
- RE: MEDM crash Mark Rivers via Tech-talk
- Re: MEDM crash Jeong Han Lee via Tech-talk
Re: MEDM crash Siddons, David via Tech-talk
Re: Seeking config advice for smarAct MCS controller Juliane Reinhardt via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
