Subject: Re: MEDM crash
From: Torsten Bögershausen via Tech-talk <[email protected]>
To: Mark Rivers <[email protected]>, 'Jeong Han Lee' <[email protected]>, "Johnson, Andrew N." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 23 Oct 2020 08:18:45 +0200
There is a trial to improve the situation:
https://github.com/epics-extensions/medm/pull/3
BR
/Torsten
On 10/22/20 10:36 PM, Mark Rivers via Tech-talk wrote:
That fixed it.  I should have noticed that the Makefile has a commented out line to do that.  This is the "git diff" that fixes the problem.
-USR_LIBS_Linux = Xm Xt Xp Xmu X11 Xext
+#USR_LIBS_Linux = Xm Xt Xp Xmu X11 Xext
  #Xp is not available and not needed on Linux Mint 18
-#USR_LIBS_Linux = Xm Xt Xmu X11 Xext
+USR_LIBS_Linux = Xm Xt Xmu X11 Xext
-----Original Message-----
Sent: Thursday, October 22, 2020 3:34 PM
To: Johnson, Andrew N. <[email protected]>
Cc: Mark Rivers <[email protected]>; EPICS tech-talk <[email protected]>
Mark,
Try to compile without Xp. makefile should contains
instead of
Han
On Thu, Oct 22, 2020 at 1:30 PM Johnson, Andrew N. via Tech-talk <[email protected]> wrote:
IIRC there are some libraries that are no longer needed and that might be one of them, try modifying the Makefile to take that out and see whether it builds.
- Andrew
On Oct 22, 2020, at 3:22 PM, Mark Rivers <[email protected]> wrote:
Ø  As Bob pointed out you have an empty include path in your build. The last -I option there was eating up the -MM which explains the error message, so one of your extensions config variables was probably empty.
I solved that.  I was missing this file that needs to define X11_LIB and MOTIF_LIB:
extensions/configure/os/CONFIG_SITE.linux-x86_64-ub18.linux-x86_64-ub1
8
However, now I get this error:
    -lANLwidgets -lPrintUtils -lca -lCom -lXm -lXt -lXp -lXmu -lX11 -lXext   -lpthread   -lreadline -lm -lrt -ldl -lgcc
/usr/bin/ld: cannot find -lXp
collect2: error: ld returned 1 exit status
/corvette/usr/local/epics/base/configure/RULES_BUILD:212: recipe for
target 'medm' failed
I have Googled to see what package provides libXp.so on Ubuntu 18, and I can’t find it.  Others have the same problem.
Pete and Bob how did you install libXp.so?
Sent: Thursday, October 22, 2020 3:14 PM
Cc: Soliday, Robert T. <[email protected]>; EPICS tech-talk
<[email protected]>
On Oct 22, 2020, at 1:54 PM, Mark Rivers <[email protected]> wrote:
That PR builds OK on Centos 7, but it fails to build on Ubuntu 18.  I see the same failure on Ubuntu 18 with the MEDM_3_1_14 tag.
TahoeU18:/corvette/usr/local/epics/extensions_new/src/medm_fix> make
make -C ./printUtils install
make[1]: Entering directory '/corvette/usr/local/epics/extensions_new/src/medm_fix/printUtils'
make -C O.linux-x86_64-ub18 -f ../Makefile TOP=../../../.. \
    T_A=linux-x86_64-ub18 install
make[2]: Entering directory '/corvette/usr/local/epics/extensions_new/src/medm_fix/printUtils/O.linux-x86_64-ub18'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I/corvette/usr/local/epics/base/include/compiler/gcc -I/corvette/usr/local/epics/base/include/os/Linux -I/corvette/usr/local/epics/base/include   -I../../../../include       -I    -MM -MF xwd2ps.d  ../xwd2ps.c
cc1: error: to generate dependencies you must specify either -M or -MM
- Andrew
Complexity comes for free, simplicity you have to work for.
MEDM crash Siddons, David via Tech-talk
RE: MEDM crash Soliday, Robert T. via Tech-talk
Re: MEDM crash Johnson, Andrew N. via Tech-talk
Re: MEDM crash Mark Rivers via Tech-talk
RE: MEDM crash Mark Rivers via Tech-talk
Re: MEDM crash Jeong Han Lee via Tech-talk
Prev: RE: Seeking config advice for smarAct MCS controller Mark Rivers via Tech-talk
Next: Thank you! Maren Purves via Tech-talk
Prev: RE: MEDM crash Mark Rivers via Tech-talk
Next: Re: MEDM crash Siddons, David via Tech-talk
