1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Archiver Appliance PVs never connect to be archived, always "Initial Sampling"
From: Jeong Han Lee via Tech-talk <[email protected]>
To: "Shankar, Murali" <[email protected]>
Date: Fri, 30 Oct 2020 16:55:32 -0700
Thank you again!
Best,
Han
On Fri, Oct 30, 2020 at 3:35 PM Shankar, Murali
<[email protected]> wrote:
> >> so do we need to restart only the engine?
> For EPICS configuration, only the engine should be fine.
> For the policy file, you don't need to restart anything.
> Hope that helps.
> Regards,
> Murali
> ________________________________
> From: Jeong Han Lee <[email protected]>
> Sent: Friday, October 30, 2020 2:29 PM
> To: Shankar, Murali <[email protected]>
> Cc: [email protected] <[email protected]>
> On Fri, Oct 30, 2020 at 1:52 PM Shankar, Murali
> > Yeah; you have to restart the engine for changes to the EPICS environment to take effect.
> Got it.  I have one more question on them, so do we need to restart
> only the engine? or all four services?
> > The policy is reloaded every so often and thus can be updated at run time.
> Is this policy file? So, in terms of policy file, we don't need to
> restart the engine. Is this correct?
> Thank you, always.
> Best,
> Han
> > Sent: Friday, October 30, 2020 1:32 PM
> > Hi Murali,
> > I have one naive question about the following situation.
> > After the archiver was started, in case that I have to change these variables.
> > * Should I restart the service after changing these variables?
> > * If so, is there any way to update them while the archiver is running?
> > Best,
> > Han
> > On Fri, Oct 30, 2020 at 7:55 AM Shankar, Murali via Tech-talk
> > > The archiver needs a proper EPICS setup for it to connect to the IOC's. The engine's arch.log should print out the actual CA configuration being used so you can look there to see if the EPICS setup was inherited correctly from your .profile.
> > > Regards,
> > > Murali
RE: Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Shankar, Murali via Tech-talk
Re: Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Jeong Han Lee via Tech-talk
Re: Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Shankar, Murali via Tech-talk
Prev: Re: EPICS7 and RTEMS5.1 Testing Johnson, Andrew N. via Tech-talk
Next: Re: EPICS7 and RTEMS5.1 Testing Matt Rippa via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Shankar, Murali via Tech-talk
Next: ca-gateway and PUTACKS Ben Franksen via Tech-talk
