1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: [EXTERNAL] RE: Timestamping Confusion
From: "Hartman, Steven via Tech-talk" <[email protected]>
To: "Manoussakis, Adamandios" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 16 Dec 2020 19:00:43 +0000
> On Dec 16, 2020, at 1:21 PM, Manoussakis, Adamandios via Tech-talk <[email protected]> wrote:
> Currently we are using caLab implementation (so far works great for what we need which is to just put/get into PVs)
It sounds like you are using caLab as a CA client. caLab can also be used as a CA server (CaLabSoftIOC.vi). If you serve the PV from the labview side, you may be able to provide the time stamp to the record directly from your labview device support for your digitizer. And then propagate this time stamp to the other records via TSEL.
Steven Hartman
[email protected]
RE: [EXTERNAL] RE: Timestamping Confusion Manoussakis, Adamandios via Tech-talk
Re: Timestamping Confusion Michael Davidsaver via Tech-talk
Re: Timestamping Confusion Ralph Lange via Tech-talk
Re: Timestamping Confusion Johnson, Andrew N. via Tech-talk
Prev: RE: Timestamping Confusion Manoussakis, Adamandios via Tech-talk
Next: RE: [EXTERNAL] RE: Timestamping Confusion Manoussakis, Adamandios via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
