Hi Juliane,
Your DBD file, example.dbd is wrong. So you have a lot of error
message in your IOC startup. Please see below "snip snip section"
Since I can get the code of this repository if this is public, could
you point me where your repository is? I cc this email to my lab
account.
And ALS also has the similar db file, which you may get more benefit
from your IOC also.
Han
--- snip snip ---
dbLoadDatabase "dbd/example.dbd"\
Declaration of recordtype(scalcout) preceeded full definition.\
Error at or before "\}" in file "dbd/example.dbd" line 10293\
--- snip snip ---
On Thu, Dec 17, 2020 at 9:53 PM Juliane Reinhardt <[email protected]> wrote:
> Hi everyone,
> Thanks for your help to build the IOC.
> I pulled the latest version with the sns specific template removed and
> rebuilt the application after modifying the configure/RELEASE file. That
> worked fine. However, when starting the IOC I get multiple errors. I
> searched for solutions but wasn't successful yet. I would appreciate if
> you could point me to some solution as I am still relatively new to
> EPICS and with every IOC installation I learn more but only after
> running into quite some issues. I attached the output of the ioc startup.
> Best,
> Juliane
> On 12/15/20 07:27, Pearson, Matthew R. wrote:
> > Hi,
> > Sorry about that. Steve is right, it's just a SNS specific template that shouldn't have been in the example IOC. I've removed the use of devIocStats from the example IOC on GitHub.
> > Cheers,
> > Matt
> >> -----Original Message-----
> >> From: Tech-talk <[email protected]> On Behalf Of Hartman,
> >> Steven via Tech-talk
> >> Sent: Tuesday, December 15, 2020 9:15 AM
> >> To: Jeong Han Lee <[email protected]>; Juliane Reinhardt
> >> <[email protected]>
> >> Cc: tech-talk <[email protected]>
> >> Subject: Re: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db'
> >>> On Dec 15, 2020, at 2:27 AM, Jeong Han Lee via Tech-talk <tech-
> >>> Please look at the example.substitutions file. It uses ioc_sns.db
> >>> within there. My first guess ioc_sns.db file is missing or is located
> >>> in a wrong directory.
> >> ioc_sns.db is a local configuration file for customizing iocStats on the SNS
> >> beam lines. It can be safely ignored / commented out.
> >> Steven Hartman
> >> [email protected]
> Juliane Reinhardt, PhD
> Project Scientist | ALS Computing Group
> Blg. 15-337E | phone: 510-486-4313
> [email protected]
> Lawrence Berkeley National Lab
- Re: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Juliane Reinhardt via Tech-talk
- lakeshore336 msi: Can't open file 'ioc_sns.db' Juliane Reinhardt via Tech-talk
- Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Jeong Han Lee via Tech-talk
- Re: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Hartman, Steven via Tech-talk
- RE: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Pearson, Matthew R. via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
