1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db'
From: Juliane Reinhardt via Tech-talk <[email protected]>
To: Jeong Han Lee <[email protected]>
Cc: Jeong Lee <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 17 Dec 2020 23:14:51 -0800
Hi Han,
Thanks for the prompt reply. The repository is here: https://github.com/mp49/lakeshore Yes I saw these error but then when I looked into the dbd or db files I could not see what the actual issue was.
Juliane
On 12/17/20 23:11, Jeong Han Lee wrote:
Hi Juliane,
Your DBD file, example.dbd is wrong. So you have a lot of error
message in your IOC startup. Please see below "snip snip section"
Since I can get the code of this repository if this is public, could
you point me where your repository is?  I cc this email to my lab
account.
And ALS also has the similar db file, which you may get more benefit
from your IOC also.
Han
--- snip snip ---
dbLoadDatabase "dbd/example.dbd"\
Declaration of recordtype(scalcout) preceeded full definition.\
Error at or before "\}" in file "dbd/example.dbd" line 10293\
--- snip snip ---
On Thu, Dec 17, 2020 at 9:53 PM Juliane Reinhardt <[email protected]> wrote:
Hi everyone,
Thanks for your help to build the IOC.
I pulled the latest version with the sns specific template removed and
rebuilt the application after modifying the configure/RELEASE file. That
worked fine. However, when starting the IOC I get multiple errors. I
searched for solutions but wasn't successful yet. I would appreciate if
you could point me to some solution as I am still relatively new to
EPICS and with every IOC installation I learn more but only after
running into quite some issues. I attached the output of the ioc startup.
Best,
Juliane
On 12/15/20 07:27, Pearson, Matthew R. wrote:
Sorry about that. Steve is right, it's just a SNS specific template that shouldn't have been in the example IOC. I've removed the use of devIocStats from the example IOC on GitHub.
Cheers,
Matt
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Hartman,
Steven via Tech-talk
Sent: Tuesday, December 15, 2020 9:15 AM
To: Jeong Han Lee <[email protected]>; Juliane Reinhardt
<[email protected]>
On Dec 15, 2020, at 2:27 AM, Jeong Han Lee via Tech-talk <tech-
   Please look at the example.substitutions file. It uses ioc_sns.db
within there. My first guess ioc_sns.db file is missing or is located
in a wrong directory.
ioc_sns.db is a local configuration file for customizing iocStats on the SNS
beam lines. It can be safely ignored / commented out.
Steven Hartman
[email protected]
Juliane Reinhardt, PhD
Project Scientist | ALS Computing Group
Blg. 15-337E | phone: 510-486-4313
[email protected]
Lawrence Berkeley National Lab
[email protected]
Re: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Jeong Han Lee via Tech-talk
lakeshore336 msi: Can't open file 'ioc_sns.db' Juliane Reinhardt via Tech-talk
Re: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Hartman, Steven via Tech-talk
RE: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Pearson, Matthew R. via Tech-talk
Re: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Juliane Reinhardt via Tech-talk
Prev: Re: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Jeong Han Lee via Tech-talk
Next: Re: [EXTERNAL] Re: lakeshore336 msi: Can't open file 'ioc_sns.db' Jeong Han Lee via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
